Question about Dyna-Glo (PPH16-LP) Utility Heater
Propane heater leaves black film on windows - Dyna-Glo (PPH16-LP) Utility Heater
Why won't the fan come on when I turn on the heater? It was working last week.
You are smart to leave it off right now. It sounds like the fan motor bushings are dry or gummed up. Take the outer case off so you can see the fan motor. There may be a spot at each end of the motor to add several drops of oil each or if you can get to the shaft near the bushing of the fan motor you may try putting some oil on the shaft and rotate the fan to work it in to the bushing. It is most likely time to replace the fan motor.
Feb 25, 2015 | Electric Arctic King WWJ1-12ERN1-MI8...
The propane heater is spitting out black smoke
Make sure you have enough combustion air to mix with the fuel
Dec 15, 2013 | Heating & Cooling
I just cleaned my jets on my purex mini max plus 400 heater. It is heating great now but has black smoke coming from the top. I think it is rich and is getting too much gas. Is there an adjustment or do i...
First have you always had this connected to propane? There are different models for natural gas and for propane.If you connect a natural gas to propane the "jets" are way too big for propane. How did you clean the jets? IF you "drilled" them out they may be too large now. If you have adjusted the gas regulator, decrease gas pressure. I believe this unit has a combustion blower, be sure it is debris free on inlet and in fan, check for leaves. Make sure black smoke is not coming from debris built up inside of heater. Here is a link to a location for the complete manual for your heater: http://lawnandgarden.manualsonline.com/manuals/mfg/pentair_pool_products/400k_btu_hr.html
Jul 05, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
Propane leaves a flim on my windows nothing i use seam to take it off
Hard to say what this is but your windows should not be within a 4' laterl of the window for this and many other safty reasons. Sorry to say but you should move the heater away from the window.
Apr 02, 2010 | Sta Rite Maxi Therm 400k Btu Propane...
Black smoke from propane heater. I can not see it but i see black on the walls
INCOMPLETE COMBUSTION, MAKE SURE IT IS GETTING ENOUGH AIR, YOU DIDNOT STATE WHAT TYPE, CHECK ANY AIR FILTERS, DUST, CLEAN WITH COMPRESSED AIR IS WHERE I WOULD START, GOOD LUCK
Jan 22, 2010 | Reddy Heater RLP100 Portable Forced Air...
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
Broken adjuster for propane heater
Broken adjuster for two burner attachment. Cant find a replacement.contact budmtzgr@sonic.net
Jan 30, 2009 | Dyna-Glo Double Tag-a-long Heater
Empire Wall Heater(propane) won't stay lit
You have a crack in your heat exchanger and it is sucking in products of combustion. Replace the heater. OR there is a blockage in the intake or exhaust vent. GET IT FIXED OR REPLACED!
Dec 05, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Dyna-Glo (PPH16-LP) Utility Heater Logo
111 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
