Question about Kenmore 43142 Front Load Washer
My Kenmore Eco System front load washer seems to have a valve stuck open. When i turn it on it starts to fill but the water just drains straight out. What do i need to look for to fix this?
  • Kenmore Master
  • 17,130 Answers
The drain valve/pump is struck or clogged with dirt so that it is not shut. So remove from the bottom the drain hose to get the valve out , check if the valve is working after cleaning with an external voltage as it will open & close. If not the valve must be changed.
It is also possible that the program controller can be short in the drain output and is constantly keeping the valve opened. So release off power in the first place to confirm and if still the water drains we have the culprit.
Posted on Sep 29, 2010
Hello. I installed a new never used Kenmore washer today front load. As soon as we turned the water on at the back of the machine the water stated to enter the unit, Even when there was no power to the...
Not come across anything like it before, however, check your manual and see what it says about the position of the valve at the back of machine, if you've not already done so....otherwise goodluck.
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
417.43142300 Kenmore drains while trying to fill with water
try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Oct 27, 2009 | Kenmore 43142 Front Load Washer
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
Will drain not fill up and eco button flashes
check if any of the valves are getting voltage,if they are and still not filling,turn off machine and unplug-coil far valve should be around 3.4kohms,they go open circuit sometime,check the small pressure switch pipe for blockage aswell hope this helps----follow safety guidelines always when working on electrical equipment
Apr 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Water in Barrel
sounds like a bad water inlet valve stuck open and permitting water to enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer filling up while turned off
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washer Is Dribbling Water Into Tub
you have a bad inlet waer valve stuck in open position, youll need to replace the valve. easy enough to do, its the valve your hoses are screwed into, in the mean time until repair is made, you can simply turn offf water supply between loads ( not a bad thing to do anyway)
Apr 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
76 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
