Question about Philips Norelco 8175XL Electric Shaver
The norelco shaver 8175 won't hold a charge - Philips Norelco 8175XL Electric Shaver
  • Philips Master
  • 1,612 Answers
Sounds like the battery is bad. It will need replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-liion-battery-cell-p-578.html
To replace, first remove the back cover by removing 2 screws. Then you will need to remove a second 'inner cover' by removing an additional 3 screws. You can then access the battery. For easiest replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Sep 29, 2010
My shaver would not hold its charge then finaly just stoped running
Sounds like the battery is dead. A replacement battery for model 7775X can be purchased at the link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
Mar 26, 2013 | Norelco Cool Skin 7775X Electric Shaver
Razor heats up when i charge it and it won't turn on
Most likely, the batteries are bad. If the charging light still illuminates when plugged in, you should be able to change the batteries to fix the problem.
You will find the correct batteries for model 4865XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Scroll down the page for helpful tutorial videos
Oct 11, 2011 | Norelco Micro Action Shaver 4865XL...
Will not hold a charge. model 7617x norelco
According to your problem, you have to change the battery with a new. After several times of charging and uses charging battery also get dry. Then the battery can't hold charge. Only you have to switch a new cell.
May 13, 2011 | Norelco Quadra 7617X Electric Shaver
Battery won't hold charge. What model replaced this model?
The Quadra Series was replaced by the Speed-XL series of shavers. That series has also now been discontinued but you can still purchase one at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-8170xl-speedxl-shaver-factory-refurbished-p-296.html
or
http://shaveroutlet.com/philips-norelco-8240xl-speed-xl-shaver.html
Sep 20, 2010 | Norelco Quadra 7845 XL Electric Shaver
My Norelco 5615x doesn't hold a charge. Can I
To open the shaver you first need to remove the lotion compartment cover on the back. Then remove the screws to take off the back cover and access the inside of the shaver.
You will find replacement batteries for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Jul 15, 2010 | Norelco Advantage 5615 X Electric Shaver
Norelco shaver doesn't recharge.
If the shaver won't hold a charge it usually means that the batteries need replacement. This requires disassembly and soldering skills. It's not hard to do but if you're not handy with a soldering iron a shaver repair shop can do the work for you. However, if you have to pay to have it done and if the blades are more than two years old and need replacement, you might be better off just buying a new shaver.
Jul 05, 2010 | Norelco Cool Skin 7775X Electric Shaver
MY RAZOR BATTERY NO LONGER HOLD A FULL CHARGE. ARE REPLACEMENT BATTERIES AVAIALBLE, AND IS REPLACING THE BATTERY A REASONABLE SOLUTION?
mcdevito75 here, Some Norelco batteries can be changed and others not, it depends on the model you have, Online Norelco shavers.com
Jul 02, 2010 | Norelco Spectra 8831 XL Electric Shaver
Philips Norelco 8175XL Electric Shaver Logo
212 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
