Question about Ryobi Backpack Blower 25.4cc
Need to know correct oil-gas mix for Ryobi backpack blower
SOURCE: The trigger on my ryobi backpack is not functioning properly.
You need to buy a new cable, clarified by Ryobi Tech Support.
Posted on Jan 23, 2009
  • 272 Answers
SOURCE: Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
Posted on May 12, 2009
mattofilms
  • 110 Answers
SOURCE: i just picked up a used ryobi rgbv3100 mulcher
test for spark.
while spark plug is out - put finger over hole see how much compression there is.
If good spark - look for holes in fuel line.
Posted on Jul 06, 2009
wireguy212
  • 1627 Answers
SOURCE: What type of oil goes in the Ryobi 08570 Blower?
You need 2 stroke motor oil or chain saw oil.Mix it according to the lable to make up 50:1 oil/gas mix.
Posted on Nov 07, 2009
rwvanlue
  • 486 Answers
SOURCE: ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 25, 2009
Ounces per gallon
The Ryobi manual says 50/1 which is 1 gallon to 2.6oz 2cycle oil
Oct 07, 2013 | Ryobi Backpack Blower 25.4cc
Ounces per gallon 31 cc engine
If this is a 2-cycle engine, Ryboi are 50:1 check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 50:1 ratio (1 gal.) Gas to 2.5 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
My ryobi 350 cfm 180 mph gas backpack blower just stop andwont start again and my brother in-law said my mixture of gas to oil is not correct,less oil was mix how can i remedy the problem.
PROBLEM Engine fails to start. CAUSE - REMEDY No fuel in tank - Fill tank. Spark plug shorted or fouled - Replace spark plug. Spark plug is broken. (cracked porcelain or electrodes broken) - Replace spark plug. Ignition lead wire shorted, broken, or disconnected from spark plug - Replace lead wire or attach to spark plug. Ignition inoperative - Contact authorized service center.
Aug 21, 2011 | Ryobi Garden
What is the gas oil ratio of the ryobi leaf blower
Most Ryobi products made in the past 5 years use a 50:1 fuel mix. Check the fuel cap to see if it is listed there. The older Ryobi product used a 32: 1 fuel mix ratio and it was usually listed on the sticker that shows you how to work the choke. If in doubt, go with the 32:1 ratio. The only thing it will cause is premature fouling of the spark plug. Too little oil in the mix will cause premature engine wear.
50:1 is 2.6 ounces of 2 cycle mix to each gallon (U.S.) of gasoline.
32:1 is 4.0 ounces of 2 cycle mix per gallon.
I recommend to use a 2 cycle mix that is specifically designed for lawn equipment and contains fuel stabilizer. The ones with stabilizer will usually be .5 ounces larger.
Nov 30, 2010 | Ryobi Backpack Blower 25.4cc
RYOBI BACKPACK CRANKS BUT SHUTS OFF AFTER RUNNING ABOUT 10 MINUTES
Make sure you running gas/oil mix in it and you dont have too much oil. It may also need a carb cleaning/adjustment
Nov 10, 2009 | Ryobi Backpack Blower 25.4cc
What type of oil goes in the Ryobi 08570 Blower? What is the oil gas mix ratio?
Nov 07, 2009 | Ryobi Backpack Blower 25.4cc
Gas mixture for ryobi 25cc blower
buy a sythetic oil for two-cycle and the mix will not mater,it will cover 16-1 to 50 -1(note if it says mix one bottle or tube to 1 gallon,mix it 1 to 8 tenths of a gallon,always runs a little better and extends the life of your machine
Jul 04, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower 25.4cc Logo
195 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
