Question about HP Officejet 5610 All-In-One InkJet Printer
Fax picking up over phone number
Hi-- I am using an HP 5610 all in one with a new imac--i loaded the newest software for the HP on the mac and now the fax is picking up when my voice number is dialed.
  • Eugene613 May 27, 2008
    Thanks for the help. Seems to be working now.
    Problem Solver:
  • 6 Answers
Do you have an Answering Machine?
If yes then the Rings to answer on the Fax should be more than the rings to answer on the Answering machine.
Press the Setup button on the Printer and then go to Basic Fax setup and you will get the Rings to Answer option there.
Posted on May 27, 2008
Just bought an iMac running Mac OSX v10.6.7. Have a HPLaserJetM1005 Downloaded latest software & drivers from HP Can print ok but does not recognise scanner What do I do to make it scan
Hi, you can download the newest software here at HP:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&tool=&query=M1005&product=1839460&lang=en&
Remember to select for MAC os.
Wait until the installation program tells you to connect the printer.
Once installed choose the hp sollution center and select scan mode.
You can choose to scan a paper or a picture.
Hope this will help you.
Apr 01, 2011 | HP LaserJet M1005 Printer
Hp office jet 5610 all in one printer--- am I able to fax without hooking up to a computer if yes how- thanks
All the HP office all-in-ones fax without computer hookup, simply place the fax on the load tray face up until you see the window state that the original is loaded. Then on the number pad dial the fax number you want to connect to, once that is done...press the black fax button and the machine will dial the number, once a connection is made the fax will feed itself through and complete. The only connection needed is an outgoing phone line. Just make sure that the phone line is in the right socket on the back. You will see icons by the sockets, the one with the phone icon is for a line to go to a phone headset....this is not the socket for the main phone line, ise the other one that says "line".
Jun 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Hp all in one 5610 wont receive fax and phone line does not go on double ring . incoming fax shows phone off hook when trying to receive fax.no ready appears
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab2
Jul 07, 2009 | HP Officejet 5610 All-In-One InkJet...
When we are sending fax getting communication error
hi,
ab49
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
How to fax with the hp 5610 officejet printer
hi,
ab86
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Won't pick up fax line automatically
hi,
ab104
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp5610
hello with witch windows do you work???
Jan 13, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
