Question about Canon MP610 Photo All-In-One Printer
Canon MP610 wireless printing/MAC
I'm receiving a 306 error msg when trying to print wirelessly to my MP610 from my MacBookPro, running 10.5.2. I use the airport extreme as my wireless router.  The printer was working fine but just stopped mid-print and can no longer route the print jobs.  I see the printer on my printer list as my default printer.  Any suggestions would be appreciated. thanks
  • want2print Jun 03, 2008
    I use 10.4.11
    I can only print to MP610 directly from MacPro to printer. If I use the airport, my macpro won't see the printer. Is there a fix for the driver or a work-around driver to use?
5 Suggested Answers
SOURCE: can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Posted on Apr 10, 2008
I have airport extreme and 4 apple computer(all with Leopard) connected, all is working well, except I  can NOT print wirelessly  via canon mx310.  The USB cable from printer is connected into the airport extreme USB hub,, and I have the lasted canon upgrade, do you  have any suggestions?
Thanks
Posted on Jan 03, 2009
SOURCE: Canon MP620 Wireless All-In-One can't print to it
Hi
I had exactly the same problem. Here is how I solved it.
I deleted all the previously installed items (although this might not actually be necessary). Then I re-installed using the 'Easy Instal' option from the CD.
The CRUCIAL part is this: - after you have tested your connection to the printer - and it is all fine - another box should appear with a MAC address for the Scan Twain. Highlight the string of numbers and click APPLY.
THEN THE MOST IMPORTANT BIT - look at page 54 in the set-up guide. And follow the instructions which are:
When the printer utility opens click ADD - then go to 'more printers' select the MP620 with the string of numbers after it. This is the one you want NOT the one that appears automatically when you complete the installation.
make this printer your default and away you go! That should work as it has for me and i have been pulling my hair out on this for about 3 weeks!
Posted on Mar 02, 2009
Actually, I'm just clarifying Solution #2 - that IS the correct answer, but it could be stated a bit more clearly, at least under Snow Leopard. This is what was originally written:
Here's how I would rephrase it:
Under Mac OS X 10.6, go to System Preferences:Print & Fax. Click '+' to add a new printer, select Default in the top, left corner of the Add Printer window, then wait for 15-30 seconds. You'll see another Canon printer appear on the list, with a string of numbers after its name. This is the one you want, NOT the one which is already there when you first click Default. After you select that printer (do a Test Page to verify it works), you can go back and edit it, trimming the name down by cutting off the string of numbers; doing so will not affect the printer's operation. :)
Posted on Mar 21, 2010
Why does it say no paper? The tray is full. I'm working from an iPad air2.
most likely it is not picking paper, not that it doesn't have paper.
look down into the printer from the front where your paper goes and watch it when it tries to pick up a piece of paper. if the rollers are dirty with dust or such they aren't as tacky as they should be and aren't getting ahold of the paper. get a dab of dish soap on your fingertip and get it on the pick up roller and scrape at it with your fingernail. you will see the dirt coming off of it. wipe it off with a damp cloth and let it dry. it should be stickier than it was and be able to grab paper now.
Feb 09, 2016 | Canon PIXMA MG3520 Wireless Inkjet Photo...
What's your problem?canon i9100 error 306
When you attempt to print from your Canon Printer using a Mac, a message appears stating Error 306. Solution
  1. Click the Apple icon in the top left of the screen.
  2. Click System Preferences.
  3. Click Print & Fax.
  4. If the padlock in the bottom left is locked:
    Click it, enter your password and click OK.
  5. Click the - button. to remove the printer and the + to add it again leaving the options on default..
May 18, 2012 | Canon i9100 InkJet Photo Printer
Can't print
I had the same WiFi problem, reconnected by USB and failed again. However, cleaned up printer settings on the iMac and reinstalled. Now it works but I am dissapointed about the WiFi.
Amazingly hard to find info on the Canon Support Site...
Jul 22, 2010 | Canon Office Equipment & Supplies
I want to print black and white at times but can't seem to find a way to do this with the canon mp610 on my mac running safari.
You should be able to set it in your printer properties.
Select - Advanced - Printing defaults - Main - Check "Greyscale Printing".
Apr 29, 2010 | Canon MP610 Photo All-In-One Printer
Printer says error 306
buy a different kind of printer
Apr 12, 2010 | Canon MP610 Photo All-In-One Printer
My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Mar 01, 2010 | Canon MP610 Photo All-In-One Printer
Since upgrade MacBookPro to Snow Leopard it will not wireless connect to D-Link DSL 604T. Is there a firmware upgrade for this wireless router for use with MacBookPro running Mac OSX 10.6.1 please? My...
When you try to connect to the wireless network, Do u get any error message ?
You said that your other wireless is working properly.
that means the router is working properly.
Check the wireless security settings of the router. Do not change the wireless settings, just check the wireless settings.
You will need to open the Web Interface of the router.
Click Here for more info
Oct 22, 2009 | D-Link DSL-G604T Wireless Router
My Mac os X v 10.5.5 suddenly won't print to my Canon MP600. I keep getting error number 306. I have restarted both the printer and Mac. I have restarted my wireless airport. Nothing works. Any ideas?
My MP600 came up error 306 for no reason. I unplugged everything and plugged it back in again (I found a clump of dust at the USB port on the hub, which could have been involved) - the printer worked again no problem.
Jan 09, 2009 | Office Equipment & Supplies
Hi
Dec 28, 2008 | Canon MP610 Photo All-In-One Printer
Error msg status 1
sounds like a communication error, are you wireless?
try connecting direct.
Feb 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
1,616 people viewed this question
old marine
old marine
