Question about Konica Minolta bizhub C450P Laser Printer
BizHub 751 menu screen is stuck on the large hourglass. Rebooting the BizHub 751 does not resolve the problem as it just goes back to the hourglass. Any suggestions??? Thanks, Bruce
2 Suggested Answers
SOURCE: how do i shut off the beeping sound on a bizhub
It is in the accessibility options. Took me forever to find it!
Posted on Feb 18, 2011
Drum unit replacement steps
Is the drum not part of the toner? Usually they are in a unit that slides into place but if not you may need to call an engineer to have a look
Jul 07, 2014 | Konica Minolta Bizhub 751...
Scan bizhub 751
have a tech come out service mode and clear memory
Apr 16, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub 751 c 3803
Sir/Mam,
Turn off the main both power switch one located inside the front door, second on the control panel, then wait ten seconds. then turn on main inside first. Then holding down the utility/counter button turn the sub power switch on. You must keep the utility button down The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit check. Have a qualified tech look at it. :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! Fire could occur that would ruin a perfectly good day!!!!
Jan 08, 2014 | Minolta bizhub 350 Black and White Copier
Konica minolta bizhub press 1250 p c-2101
Charge cleaning assy. error. There is a very fine gold plated wire that is above the drum on the drum cart. Must be remove to be seen. Well there is cleaning device for that wire. you may hear it some time when you turn on the machine. Well its stuck or the motor (bad/Stuck) or sensor that tells the machine the cleaner is back home mite be dirty/Toner. Remove the drum cart and check it out. There is also the same system for the transfer/separation wires that are below the drum which the paper goes over as the drum transfers the image to the paper.
Oct 16, 2013 | Konica Minolta Developer 02xk Dv710 for...
Fault code c2401 on 750 bizhup
Check Erase Lamp, Update firmware if both of earlier didnt resolve the issue change printer control board it defenatly resolve the issue.
Jul 19, 2013 | Konica Minolta Developer 02xk Dv710 for...
Bizhub 350 copier lcd just blue no menu display
IF WHEN power up machine goes to a bright blue screen and then the machine is stuck and it does nothing further.
Description:
Blue screen and the machine is locked up.
Solution:
CAUSE: Failed control panel (UN1).
Oct 29, 2008 | Office Equipment & Supplies
Shows a black screen with an hourglass
the player comes on to a black screen with a hourglass. what do I do?
Jan 24, 2008 | Delstar DS-2822 / DS-2832 / DS-2842 /...
Cannot access Music and Voice menus
When i turn on my mp3 player, it will only display the initializing screen and will not stop and i cant access the music menue or any other menues
Aug 27, 2007 | Audio Players & Recorders
Konica Minolta bizhub C450P Laser Printer Logo
394 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
