Question about NorStar Lands Phones
We have a Compact ICS 4.0 with five lines. The first two lines are lit up as if someone is using them but we've reset all the phones and they're still lit up. Is there a solution to this?
    President:
  • NorStar Master
  • 860 Answers
They're tied up in the system the best way to clear them is to unplug the power cord to the CICS and re- plug it in. The system will take about 10 seconds or so to fully boot up.
Posted on Sep 29, 2010
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
I have two lines lit up that will not disconnect
when you press the line button it may say "in use" and the have a extension #. That will tell you which phone or port has seized it.
May 08, 2012 | Nortel T7316E 2-Line Corded Phone
Installed this NT9K08AD03 where a NT8B30AD03 was and the new phone does not work. Meridian Compact ICS 2.0
The M2008 set (NT9K08AD03) doesn't work on a CICS system. It works with the Meridian PBX systems. The type of sets that work with a Compact ICS system are M 7100, 7208, 7310, 7324 and T 7100, 7208, 7316, 7316e as well as some of thier cordless sets.
Oct 01, 2010 | NorStar M2008 PBX Phone (nt9k08ad03)
How to change the prime telepone for a phone line
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key(bottom right arrow).
the display should say LINES
press the show key (top right arrow)
the display should say trunk/line use
display should say line type:public
press the next key (lower right arrow) til you see prime set
press the show button(top right arrow)
press the change key and enter in the new prime set extension
press the next key ( lower right arrow)
press the release key
Sep 02, 2009 | Lands Phones
NorStar ICS Caller ID Upgrade
Yes, this is correct. install the co card with cid and you should be fine.
Dan
Jun 07, 2009 | NorStar Compact Ics WithClid Trunk Mod...
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Jul 29, 2008 | Nortel Meridian M7208 Corded Phone
Nortel Compact ICS 4
Hi Yolanda,
You did not mension what type of voicemail you have installed with the phone system so I'm assuming it is also a Norstar.
To record your Primary Greeting:
1. Press " Feature 9 8 1 "
2. Enter your password ( Default is 0000 )
3. Press " OK or * "
4. Press " Admin or 8 "
5. Press " Greet or 2 "
6. Press " Record or 1 "
7 Press " Prime or 1 "
Display should read " Record new ? "
8 Press " Yes "
Display shows " Record Greeting : "
9. At the tone record your Greeting
10. Press " OK or # " to end recording
Jul 25, 2008 | Lands Phones
Two lines stay lit
I suspect someone disabled lines 3 and 4 on these phones.
To re-enable these lines:
1. Press PROGRAM
2. Press *
3. Press #.
4. Enter one digit on the keypad for the line number.
2=L2
3=L3
4=L4
5. Press 0 to turn the line off, or 1 to turn the line on.
6. Press Trnsfer. You will hear a confirmation ring if you entered the data correctly.
Alternately, you may have only plugged the line into the L1/L2 jack on the back. This phone does not take a 4-line jack, but instead takes two 2-line jacks.
May 19, 2008 | AT&T 954 Corded Phone
Compatability Issue?
What port is the line in? You will have to look in system programming under maintenance. Look and see if the port is enabled or not?
Nov 06, 2007 | NorStar M7208 Corded Phone
Lands Phones Logo
49 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
