Question about Compaq Computers & Internet
Found jumper loose in chassis. Where does it go?
    Brigadier General:
  • 10,406 Answers
If your computer is working without the jumper, take a piece of masking-tape, and tape the jumper somewhere on the inside of the computer-case, just in case that it eventually will be needed.
Posted on Sep 29, 2010
Dodge will not start
Sounds like a starter fault, before you condemn the starter, clean and check all power connections, battery to earth, battery to starter, starter to engine, engine to chassis, chassis to body. Could try using a single jumper cable, connect from earth of battery, to a good earth point on the engine, if that makes a difference, then fault found.
Dec 27, 2013 | 1999 Dodge Ram
Chasis intruded.. fatal error.. system halted!
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
Hope this helps
Jun 03, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My motherboard is asus P5KPL-AM SE when i on it...it detects the hardrives but the lower part was have this msg...."chassis intruded! and system halted! but when i clear the cmos by removing the...
theres many possibilities.... first check if loose connection of cables... also if it helps you might have to jumper hdd ...
and also try replacing cmos battery lastly make sure the chassis sensor button is pressed down when closin lid...
May 21, 2017 | ASUS P4P800-MX Motherboard
How can i disable chassis intrusion on p5kpl-am se board? the board don't have any intrusion switch...
For the chassis intrusion circuit to work, the chassis power supply must be connected to AC power. By default, on the motherboard the pin labeled chassis "signal" and "ground" are shorted with a jumper cap. You need to remove the jumper caps if you intend to use the chassis intrusion
hope this helps
Dec 07, 2010 | ASUS P5KPL-AM SE Motherboard
Chasis intruded ,after changing cmos battery also the sameproblem
Either jumper the chassis intrusion header on the motherboard with a striaght jumper(like you'd find on a hard drive), or, easier, somewhere in the bios setup you can set Chassis Intrusion detection or reporting to disable.
Sep 08, 2010 | ASUS P5GC-MX/1333 - Motherboard - micro...
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Jul 21, 2010 | ASUS P5KPL-AM SE Motherboard
Chassis intruded
try reassembling your CPU as if it is new. make sure all sockets are securely attached.
Dec 30, 2009 | ASUS A8N32-SLI Deluxe Motherboard
ASUS P5LD2-VM Chassis Intrude
Do you mean the pins for the chassis intrusion on the board are broken off?
if not broken then just jumper them and bypass the switch.
Jan 26, 2008 | ASUS P5LD2-VM Motherboard
Asus Board MOdel Number P4BGL (845 Mxl) is giving an error called Chasis opened or tampered.?
I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
" 9. anonobomber, 07-05-2002 09:51 read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check http://www.asus.com.tw for the manual pertaining to your motherboard"
Jan 21, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Computers & Internet Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
