Question about Polaris Pb4 - 60 Booster Pump
Impeller rusted on how to remove - Polaris Pb4 - 60 Booster Pump
    Novelist:
  • 116 Answers
Removing the Impeller, is actually not that bad. You say it's rusted on but I have to ask why you think it's "rusted". I have to assume it's just on real tight and you just assumed it's rusted. If your removing the impeller I have to assume either you need to place the shaft seal, the motor, or the impeller itself is bad and your replacing it. Either way the procedure is pretty much the same. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove have a cap in the middle of the tail piece and hold with a wrench, usually 9/16", or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you can unbolt the motor from the seal plate. If the Impeller is corroded, or rusted as you say and it's really hard to remove, you just have to man handle it. If the impeller breaks or the brass insert strips out, you'll have to cut it away till you get to the shaft and can use channel locks, locking pliers etc to remove the insert however necessary. It is rare for this to happen, but it can happen. Impellers can break, fail, or strip out like anything else.
Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Sep 29, 2010
How do i remove the impeller from mycraftsman 1350 series 27" snowblower
Before I begin, this is a fairly involved process so if you dont have some mechanical experience you may want to pass it off.
First you have to split the snow blower so remove the bolts on the side of the case just behind the auger case.
The three bolts just to the right of the tire must come off. Then the case will split apart. Stand the engine section against a table or something.
Tip the auger section up on its end so the pulley is facing up. you must remove the pulley by loosening the set screw or bolt on the shaft. This can be very difficult due to rust.
After you get the pulley off you will need to remove the auger assembly from the casing. You will first remove the bolts/nuts that hold the ends of the auger shaft to the side of the case. When those are off you will pull the auger shaft/gear case assembly out of the case. It will look something like this...
Once that is out, you will be able to get to the impeller bolts or pins. If you have bolts simply remove the bolts and slide the impeller off the shaft. Again, this may be difficult due to rust and/or wearing of the shaft under the impeller. If you have pins, the pins will have to be pushed through with a hammer and drift pin smaller than the pins themselves. Then you can purchase new pins. These can be purchased at a local hardware store.
Once you replace the pins, put the machine back together.
Dec 13, 2014 | Garden
My pump squeels loudly. I think it's a bearing that I can't get to because I am having trouble getting the impellar off.
If the impeller has never been removed it may not come off. Impellers unthread counter clockwise off the shaft of the impeller by putting a big flat head screw driver on the motor end of shaft.
If they have been on there for years they can become rusted onto the threads of the motor shaft.
At that point if it will not unthread then you will need to break it off.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
How do i know if the impeller is bad?
Generally if the impeller looks okay it is good to go. In the event that the pump has run hot (without water) you may find that the back of the impeller, near the seal, has deformed from the heat and it should be replaced.
As for as the seal- when in doubt, change it out. You don't want to risk wrecking a couple hundred dollar motor to save $10 on the seal.
Jan 20, 2013 | Jandy Pool & Spa
How do I remove impellor from a/o smith 7-181327-03 pool pump
If the impeller is fused onto the shaft by rust or mineral build up the chance you will be able to remove it with out destroying it are slim. You're likely going to need a new impeller and shaft seal kit, so I'd suggest getting them before your try to remove the old impeller.
First you must remove the water/plumbing and the strainer basket assembly or pump faceplate if applicable to gain access to the impeller.
Step two, on the backside of the motor (opposite side of impeller) you will find the back end of the motor shaft. This end of the motor shaft has a slot in it so that you can insert a large flat screw driver. This will help you to hold the shaft while you try and unscrew the impeller. fyi your pump might have a plastic housing on the back of the motor which you should remove to get to the back of the shaft. This is best way to remove the impeller but its likely to be a struggle if there is rust on the shaft. Good Luck
May 29, 2012 | Jacuzzi Pool & Spa
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
How to remove impeller assembly from chipper
You can download a PDF2.gif manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795890 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer2.gif where you can either save it or print it out or both
Aug 16, 2009 | Heavy Machinery
Maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Grinding noise in dishwasher. 4 day after warranty..Can I fix it myself...Need your help... Thank You, Sandi
Hi
Grinding noise is due to a cracked impeller which can be accessed by removing the spray arm. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Dishwashers
Polaris Pb4 - 60 Booster Pump Logo
855 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
