Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Switching Video cards
I went into my BIOS like you described. However I have 2 choices under the GPU. They are Enable If No Ext GPU & always enable. I did change it to always enable but did not make a difference. Any other ideas?
  • RickKelley May 29, 2008
    I did finally locate the solution for this. And no there is no DISABLE option. That being said the 1st workaround was under PNP/PCI configurations in the BIOS. When I set that to the PCI slot 1st I would get picture until windows loaded, then it all went away again switching back to the onboard. So I manually disabled the onboard video via the device manager in windows, and could use things. Just today I got a reply to the ticket I opened with ECS & found there is a BIOS update available. With that update in place if you set things to Enable If No Ext GPU & have a card plugged in the system automatically disables the onboard.
  • 2,351 Answers
Hello again RickKelley,
Think of it like this.
The board uses the onboard's GPU (Video card).
When you add a video card you want to use the new video card's GPU.
There are three settings for the onboard GPU page 36 in user manual.
Onboard GPU must be set to, Disable ,(press enter while haveing Enable high lighted) choose Disable.
Frame buffer size drop to zero (0).
You stated the only other option is (always enable). That does not match with what is typed in the manual. To download you're manual for you're ECS GeForce6100SM-M click on this link.
Please go to page 36.
ECS would not need these settings if the board didn't have PCI-E slots.
Take another look after you download the manual.
How to vote you're expert & also how to repost more questions for same problem or to answer expert's questions for a posted question.
Enter site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Add another question to the current post....
Good Luck!
Posted on May 25, 2008
Ecs geforce6100sm-m motherboard video card problem
Well there is 2 scenarios, first one: pci-e port is not good, or is not making any contact with the pins of the GC; second one, GC is not working properly or you have a warranty to claim!
Jan 23, 2012 | Computers & Internet
Onboard video died, how do i enable the agp card
if you can't see bios on start up, after pessing F8 on xp, try with F2 and F4 .. if nither of that work, try to unplug pover cable , reset bios by pulling out little battery on mother board, that how you will reset cmos, and out bios on default state. And maybe than it will enable you your agp port.. try and let me know..
Jun 28, 2009 | E-Machines T3085 PC Desktop
No display - ON-chip VGA diabled in BIOS
hi ... i think you might solve the problem by removing the battery from *********** board for about 30 seconds or even a few minutes to be sure...... this should reset your bios to factory settings... good luck !
Jan 18, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
You mean your Video Card?
To disable the your MS6786 ONBOARD GRAPHICS on your PC.
- If you know ho to proceed the BIOS System of your PC? they have choices to change you settings
Disable or Enable.
Sep 22, 2008 | Computers & Internet
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
EliteGroup ECS GeForce6100SM-M video problems
You are the fourth person I have helped with this board. One would think that ECS would have this posted on their site. Please update you're bios. Click on this link:
Two user's tried 2 different settings & each worked out fine. You made the correct setting in you're bios. After flashing the bios to the latest bios file. Re-check you're settings. You may find you're setting will function. If not you will have to change the bios setting to Enable. According to ECS the bios will automatically turn off the onboard video. As I mentioned, this does & does not work. Try both settings if Disable fails to load with out the blue screen.
Good Luck!
Jun 07, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Video Card Chnage
Hi Rick, you need to disable the onboard video from within you're bios. Please go to page 28 in you're manual. This will show you how to enter the bios menu. Once there go to page 26, where you will find. Onboard GPU (Enable If No Ext GPU) set this to Disable. Save & exit you're bios. You're system will auto restart. Once windows has finished loading, install the driver software for you're PCIE card. Suggest you check for updated driver software for you're PCIE video card.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
May 24, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
My computer beeps on start up nothing on screen and beeps over and over again, I checked the jumpers, checked hte cpu pins for damage, check the RAM and replaced with new to test, checked my drives nothing...
Try putting in a PCI vid card. Just an older one. Not a PCI- Express unless you have one.
I had the same problem. And the dipwits at ECS programmed the BIOS to default with an PCI vid card. Not on-board.
Then, just go into BIOS and change the boot 'Init Display first' to "on board" or something like that under PnP/PCI Configurations.
Under "Advanced Chipset Features" 'Onboard GPU' make sure it is {Enable if No EXT GPU] or always enable or something like that.
Believe me I had the problem. Was ready to dump it, or do a RMA. Messed around for a year and 1/2 then as a last resort put in an old 2mg PCI card. And it booted right up. I was pissed as hell that they would set the default to an EXT card on a board that claims to be ONBOARD video. Believe me they are going to hear about it.
Also depending on the ram installed. As I am having this problem. Now. It defaults to single channel DDR2. And I can only get 1 533 stick to work. For some reason, the board refuses to post when I have the second of a matched pair in the slot. So if you have that - try taking out the second stick. But try the video deal first.
Feb 13, 2008 | ECS C51GM-M Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
65 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
