Question about HP Officejet 7000 Wide Format Printer (C9299A)
I recently recieved a new 7000 printer. I was not given any directions. The IT department set it all up . They told me it would use the initial ink cartridges pretty quick. On the front of the machine the yellow light is flashing. The M and K indicators are lit . The light adjacent to the on off button is flashing. I am unable to print anything. I am think I am out of ink, but with no directions, I am not sure.
    Scholar:
  • 78 Answers
The lights indicate you are out of Magenta and Black ink. Replace the carts. When you purchase them, make sure to buy the XL versions, as they have a much lower cost per page.
Posted on Sep 29, 2010
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Boa tarde, Referente Epson 7000 Pro, erro fatal SERVICE REQ 000000 101. Como entrar no meu para resetar o waste ink system? Att
When is printers depletable supplies like ink, print paper almost runout is likely for caution messages to be displayed. In this situation, the printer requires new ink cartridge replacement. Refer from the printer compartments to ascertain the model brands of the old ink to make possible acquiring from retail the most compartible or replacement.
Feb 09, 2011 | Epson Stylus Pro 7000 InkJet Printer
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Sep 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Cannot install cartridges to initialize set-up
take it off the tape in the ink cartridge maybe work
Dec 27, 2008 | HP Office Equipment & Supplies
How can I get my epson GT 700 scanner to work on windows XP
Once it is installed on Windows XP you can change the setting in properties to run Windows 98 compatible. It used to work with older scanners and printers. Try it out.
Dec 04, 2008 | Epson GT 7000 Flatbed Scanner
Just bought an HP Photosmart C7280 and am going thru initial set up. Have got to the stage where insert paper which should then run trial page before i then move onto the wi fi set up Unfortunately the...
Where did you buy the printer? Was it new? If you bought it from ebay, the seller has provided a new set of initialisation inks with a used printer. These inks only work with a printer which is brand new and completely unused. They mix with ink already in the system on first use and they cannot be used with another printer and cannot be used in a printer which has already gone through the initialisation process. There is however a work around. Let me know if you need it
Nov 30, 2008 | HP Office Equipment & Supplies
Epson Rx680 Photo all in one
Call Epson again and complain. This is a known defect on new machines shipped. I had the same problem and they sent me a new printer under warranty (same model) without any issues. The new one works perfectly.
Oct 15, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
My HP Photosmart D7360 will not print black, despite changing cartridge and performing print-head cleans
I have the same problem. I just re-installed all ink cartridges into my printer from the first actual cartridges given to me with the printer and the black ink doesn't work. I contacted HP and they told me that I needed to change my black ink, after I already told them that I have tried 2 new ink cartridges in the system. I went out and bought another one thinking that this would fix the problem, and it didn't. I contacted HP again and I was told that it was the printer that was broken. The actual black ink section was faulty. Since it was a year and a month since I bought the product it was not under warranty, so nothing could be done but to buy another faulty piece of merchandise from HP. I could also service it, but that was never given a price tag. If you want my opinion don't purchase anything from HP again, I know I won't.
Apr 22, 2008 | Office Equipment & Supplies
HP Officejet 7000 Wide Format Printer (C9299A) Logo
480 people viewed this question
Seeker5211
Seeker5211
