Question about Cameras
Camera message is: memory card requires formatting : I chose the option to format and camera will start formatting then stops and this message pops up:please format memory card or put in new memory card. I changed memory card and same thing happens,I have also tried moving switch on card, This problem started when I used card to transfer pictures to computer.
  • 68 Answers
Try formatting through the computer rather than from within the camera itself. Or, just open the card on the computer, select all, then delete. There's probably a large file in there somewhere that the camera just doesn't have enough ooomphh to move out.
Hope this helps. :)
Posted on Sep 29, 2010
Memory card will not format
If other memory cards take the format then your card is fubar.
Aug 25, 2017 | Kodak EasyShare M863 Digital Camera
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
In olympus fe 280 when i have placed the xd in the camera and turn on the camera then it displayed two options either to clean up or format then i have chosed format then it displayed after some time like...
A camera memory card should always be formatted IN the camera.
Do not format camera memory cards in a computer card reader.
If the card is formatted in the camera and after that the same error pops up,
you should replace the memory card and recheck.
Jun 15, 2011 | Olympus FE-280 Digital Camera
I havea kodak M340 and just purchased a 8GB sdhc memory card. I keep getting a message memory card requires formatting. I press OK, get a message formatting ... and then back to the same message, memory...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Aug 18, 2010 | Kodak EasyShare C340 Digital Camera
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
Aug 15, 2009 | Kodak EasyShare Z740 Digital Camera
How do I initialize the card?  The camera won't let me shoot, a message pops up says card is not initialized.
The manual gives three options if this warning shows.
(1)
The memory card has not been formatted.
To format the card select Format on Setup Menu 1.
(2)
The memory contacts require cleaning.
Clean the contacts with a soft dry cloth.
(3)
Camera malfunction.
Contact a FujiFilm dealer.
Jul 11, 2009 | Fuji FinePix S2000hd Digital Camera
Camera/computer say memory card "needs to be formatted".....
i would save your pictures on to a disc, then re-format the card.
Jan 25, 2009 | Digital Blue EasyShare MD1063 Digital...
"Internal memory requires formatting."
This error message indicates that the internal memory in the camera requires formatting or is corrupt. You must format the internal memory. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a memory card during formatting may damage the card. (Formatting internal memory also erases email addresses and album names. To restore addresses and albums, see Kodak EasyShare software Help.)
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Memory card requires formatting"
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
103 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
