Question about Carrier 50TJ028 Rooftop Electric Cool Air Conditioner
Can ypu please tell me the weight of the next chiller: MODEL: 50TJ-028-6B1YA SERIAL: 2806U15500 Or technical information Thanks
  • 382 Answers
DEAR SIR
CARRIER STANDARD EFFICIENCY AIR-CONDITIONER,S DATA ARE GIVING BLOW:
Specifications:
ELECTRIC/ELECTRIC, HEATING & COOLING 50 SERIES - CONSTANT VOLUME, VERTICAL SUPPLY AND RETURN
MODEL
NUMBER
NOM
TONS
NOM
CFM
NET
COOLING
(Btuh)
NO.
COOLING
STAGES
EER IPLV
TOTAL
kW
HEATING CAPACITY (kW)
(kW@ 460/3/60) WT
(lbs)
DIMENSIONS
(in.)
Length Width Height 50TJ028
25
7,200
268,000
9.3
30.9
32 / 55 / 80
1,850
86.125
83.5
47.25
HOPE ANSWER THE QUESTION
THANK YOU
PLEASE VOTE1
Posted on Sep 29, 2010
Savage model 110 serial number 46962 can anybody tell me about this gun?
Savage model 110 date of manufacture? ' The Firearms Forum
www.thefirearmsforum.com > ... > Technical Questions & Information I have a Savage Model 110, 7mm Rem Mag with the serial number F76xx15. I'm trying to get all my guns info on record and was wondering if anyone could...
Identifying a Model 110l [Archive] - Savage Shooters
www.savageshooters.com > ... > 110-Series Bolt-Action Rifles Jul 9, 2012 - 14 posts - ‎7 authors I have a left-hand Model 110 I'm trying to identify. I'm pretty ... It has a five digit serial number beginning with "5" and all numbers. The barrel has ... can anybody help date my 110 8 posts 26 Sep 2013 Help w/ identifying date of manufacture for Savage ... 9 posts 23 Mar 2013 Savage 110 Date of Manufacture 44 posts 15 Jan 2013 Savage Serial number whoas 21 posts 3 Jan 2013 More results from www.savageshooters.com
Savage Model 110 - Gun Collections Online
guncollectionsonline.com/savage110.htm Information on Savage Model 110, Model 110, Savage 110, Savage bolt action ... Home ' Gun Collection Appraisals ' Sell Your Guns ' Serial Number Lookup ...
IDing Savage Model 110 - Replacement Stock - Shooters Forum
https://www.shootersforum.com/.../43271-iding-savage-model-110-repla... Dec 24, 2007 - 13 posts Have a Savage Rifle, Model 110, 270 Cal, Long Action stamped with only Model 110 on the barrel. ... However the Serial Number begins with an "E". ..... You must check to insure that the bolt will not close on a FIELD gage!
I have a Savage 110 .270 serial #f342620 can anyone tell ...
www.fieldandstream.com/.../i-have-savage-110-270-serial-f342620-can-... Jan 14, 2012 - I have a Savage 110 .270 serial #f342620 can anyone tell me when this gun ... Check the crown... if you see any scratches or knicks, put an 11 ...
Savage model 110 - The Firing Line Forums
thefiringline.com > ... > The Hide > The Art of the Rifle: General Jun 13, 2013 - 9 posts - ‎8 authors To have a 110 long action rifle in a short action 300 savage it sounds like someone rebarreled it. I see that serial numbers with a Fxxxxxx are ...
Jan 11, 2016 | Optics
Weight sensor broken in electrolux washer
Hello Carol, I am happy to assist you!
Generally speaking, washers do not have weight sensor. What exactly is the issue your washer is experiencing? May I please have the model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you!
Dec 01, 2013 | Electrolux EW1000i Front Load Washer
I have a kitchen selective mod. #BC 10R I dont have the operational manual for this and cant seem to get it to work. I dont know if it is broken or if there is an operator error. Please help me out. We use...
Hello, couple things first. This is posted under a cm-202 coffee maker yet the BC-10r is a wine chiller. Yiou are looking for the instructions for the wine chiller correct? Also I am a service repair person that repairs refrigerators and coolers as well so if you can describe what the unit is doing when you turn the unit on or plug it in as well as if you can see any led lights lit on the unit as well I would be able to tell you what is also wrong with you unit also.Please provide full model numbers and any serial numbers as well on your unit. I await your reply
Thank you
Rick
Nov 24, 2011 | Kitchen Selectives CM-202 Coffee Maker
I need to find out the weight of the R-22 refrigerant that is supposed to be in this chiller unit.
Hi, you will not be able to get the exact weight thats in the unit, unless you recover it and weigh it. There should always be a data plate on the unit to tell the tech how much it holds in pounds. Some do, but some you charge by using the site glass if you have one on the unit, but if it does not say anywhere on how much R-22 it holds, they only way you have to go, is to recover it into tanks and weigh it? Are you trying to charge the unit and you want to know how much to use?? If that is the case here then, if there is no site glass on the system, you can buy one a a refrigeration parts hose and install it on this liquid line, buy a solder x solder or flare x flare and use that to see when its almost full. Even then, you could over charge the unit. The best way is to use temperature tools to measure the suction line temperature using the superheat method, or sub- cooling method. This is the only way to know how much the unit holds, as you have to consider the freon lines and all.If you can give me more information on what you are doing to this chiller, contact me by my user name and I can help you more.
Shastalaker7
A/C, Refrigeration, & Heating Contractor
Sep 19, 2011 | Heating & Cooling
Honywell whine chiller model 88058 not working
Hello friend, i had the same problem and it was solved replacing largest capacitors on board, they are 2 x 120uF(120V). You must to check that both original capacitors be damaged, you can to see it if they are inflated on the top
Jul 23, 2010 | Honeywell Consumer Products Model...
Need torque specs for 1998 zx9 crankcase lower, head cylinder, and connecting rods
Lower crank 75 ft-lb Head 105 ft-lb No specific torque on connecting rods. Just dont over crank it. Thanks for using Fixya.com
Aug 20, 2009 | 1998 kawasaki ZX-9R Ninja
My problem is that why you don't show the price of mobiles.
tell me your area kindly then (country) to tell your mobile prices
Jun 07, 2009 | Sony Ericsson w580i Cellular Phone
Whirlpool Duet GHW9400PWO, Exessive Vibration
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=906440&PPStack=1
I see your problem, try this link for part info, look around for a local store or print this and write down model and serial to call and tell em you need the rear counterweight for this model.
Sep 16, 2008 | Whirlpool GHW9400 Duet Washer
Heating & Cooling Logo
312 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
