Question about Dell Latitude D610 Notebook
Monitor does not display all the icons but a computer displays well when connected to an external desktop monitor
    President:
  • 2,992 Answers
If you mean the desktop isn't completely filling the display, you need to be sure the resolution is set correctly. Native resolution for this model is 1500x1050, according to Dell's site. (Native resolution is the one the screen was designed to best work with. Unlike older CRT monitors, some resolution settings don't work well on LCD screens.) You can check and set the resolution through the Windows control panel.
If you mean that the display is dim and hard to make out, but is okay on an external monitor, you probably have a backlight issue. Without the backlight, you can't see what's on the screen even though the display is working. The usual cause of backlight failure is a bad inverter. The inverter is a small circuit board in the display that provides power for the lamp. Replacements are available for most laptops, and changing one is normally not a major job.
Posted on Sep 29, 2010
Can i connect my laptop to a crt monitor if my unit has no display
Many laptops have the ability to connect to an external monitor. On most the monitor can be used in a manner similar to a projector output for presentations. On some the monitor can be configured as an extension of the desktop, essentially giving you a double wide screen.
If the problem with your laptop is with the LCD display and not with the display circuitry, it may be possible to use it with the external display. If the problem is not with the LCD screen, chances are that the external monitor won't work either.
Sep 08, 2016 | Computers & Internet
No display upon turn on
Did you press and hold the FN function key plus the key that toggles the display? In your case it might be the FN+F8 if F8 is the key that toggles the display.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If your video card is bad you will not see anything on the laptop's lcd screen or the external monitor.
Jun 10, 2012 | ASUS Eee PC 1005HAG Notebook
Display are not showing cleanless
Try connecting an external monitor to the computer and see if it displays better. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your video card inside the computer is good, but your lcd screen is bad. If the Borrowed monitor displays the same way with problems, then your video card inside the computer is bad.
Jun 09, 2012 | Lenovo G555 Laptop
No video
Not sure whether you have a laptop or desktop but your issue is either the lcd screen or the video card. To isolate the problem try plugging another monitor to the system. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original screen is bad and the video card is good. If the Borrowed monitor does not display anything, then the video card inside the computer is bad.
If Laptop try the steps below:
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 26, 2012 | Computers & Internet
I start up mt asus x8ac but i there is no display of the desktop. how can i fix this?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 17, 2012 | Computers & Internet
L no display
If it seems like it booted up, you hear fans running, hard drive spinning, lights, (except the display is black) then try the steps below.
For a laptop:
For a Desktop:
Try using another monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the display then your original monitor is bad. If the Borrowed monitor does not show on the display then you Video Card is bad.
May 16, 2012 | Computers & Internet
No Graphics
May 06, 2012 | Sony VAIO Digital Studio PCV-RS220 PC...
Pavilion dx7 no display
Apr 29, 2012 | HP Computers & Internet
Display problem
What's the problem with the display?
Nothing shows on the screen?
No DisplayShine a flashlight on the dark screen to see if youbarely see the icons on the desktop. If so, then the LCD Inverter isbad.
Apr 24, 2012 | HP Compaq nc6230 Notebook
Trouble hooking external Viewsonic monitor to Toshiba laptop
If I understand You are using a Monitor connecting the Monitor...
and the background is shared byboth the display however the Cursor stays only on one of them at a time.However it can be toggled among the 2.
If yes,
then this Feature is called the Extended Display.
Use the same Key Combination that you would use for external Display one More time and it should Work.
Jul 03, 2008 | ViewSonic VX924 19" LCD Monitor
Dell Latitude D610 Notebook Logo
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
