Question about Philips HDRW720 DVD Recorder
I have reset my hdrw720 and after the guide+ setup, the led displays the time and C002. At that point I have no control of the unit with the remote or panel buttons. There is no disk in the unit, I have also done the stop key and door key reset to no avail. It worked before the reset other then the occasional crash. I have cleaned all of the cable connections. Can you help?
  • 8 more comments
  • ssamsamss Sep 29, 2010
    You don't understand. I have no access to the system to even open the door. I have no control of the unit or access to the recorder after the setup menu asks me if I want to wach tv. When I hit the ok key, The unit does the red reset and when I turn the unit on, the LED displays
    12:10 PM C002.
    That is the end to any access to the unit. I have even manually opened the door from under the unit and inserted the firmware disk and tried the reset again to no avail.
    Please respond to the text I sent you.
    Thanks
    I will try that and let you know.
    Thanks
    If I do have to flash the eprom, Can you walk me through that process? I have a friend that might have any special equipment I may need.
    If I do have to reflash the eprom, Can you walk me through that?
    when I plug it back in, should I do a reset ore just plug it in and go?
  • ssamsamss Oct 01, 2010
    The hard reset did not work. The correct time did show up on the display after being left off for several hours.
  • ssamsamss Oct 02, 2010
  • ssamsamss Oct 03, 2010
  • ssamsamss Oct 07, 2010
    I have run a diagnostics test on the unit and all phases pass. The C002 is not coming up as an error. The read-out on the display is: 12:00PM C002.
  • 666 Answers
What you will want to do is look through your user guide for an error code section if for some reason the error code is not in the handbook you will want to call the tech support line to find out what exactly the problem is most of the time the lens will get debris on it and start acting up and creating problems thinking that a small particle is in fact a cd that it cannot read I would suggest before going any further that u use some compressed ait to clean off the lens inside the disk tray
hope this helps
Robb
Posted on Oct 03, 2010
    President:
  • 2,777 Answers
That C002 usually indicates a firmware error, which is a very bad thing to have displaying. Does anything display on the TV while the unit is on? It sounds like it has serious hardware issues, and that it is hard locking up... Possibly internal processor failure, or board failure, or firmware ROM failure, hard to say for sure, but it is definitely bad. If it were me personally I would replace this unit. If you happened to purchase the player with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the unit, as long as it's less than 5 years old.
Thanks Tim
Posted on Oct 02, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 03, 2010
    Did you see my previous answer?
  • Tim Grayson
    Oh I see you did and didn't like it lol, nevermind :) I can't help you further at this point.
    Tim
  • Tim Grayson
    Tim Grayson Oct 07, 2010
    Weird, I'm still getting updates to this problem, but it shows you rated my answer...
    Test response here.
    Tim
  • 11,896 Answers
I would try a firmware update.
Here is a guide to the service manual for your device:
http://www.eserviceinfo.com/index.php?what=search2&searchstring=HDRW720
Posted on Sep 29, 2010
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Sep 29, 2010
    Try doing a hard reset. Leave it unplugged for a few hours. While it is unplugged, press and hold the power button for about 10 full seconds. Wait at least half hour after pressing the power button before you plug it back in.
    You may need to flash your EEPROM which is not easy.
  • Nate Stansfield
    Yes not a problem
  • Nate Stansfield
    While unplugged, press and hold the power button for 10 full seconds. Then when you plug it back in, turn power on and see what happens.
  • Nate Stansfield
    Nate Stansfield Oct 01, 2010
    Another firmware update is available in Phillips support sitehttp://www.p4c.philips.com
    Here is the list of new features:
    CF3.2
    - Readability of DVD R Dual Layer discs has been improved.
    - Readability of commercial discs has been improved.
    I was looking into the player and you wouldn't believe all the other people having the same problem with the tv guide and the resetting.
    This 3.2 update is supposed to have all the bugs fixed and is supposed to fix your problem
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
How to do reset to rxv567 yamaha
Hello
You are asking how to reset all remote control codes, I assumes and posts this solution.
Resetting all remote control codes for external components to the initial factory settings.
Perform each of the following steps within one minute. Settings will be automatically stopped if more than one munute passes since the last operation. To reset, repeat from step 2.
[1] Press the codes set [located at the top right corner of the remote handset], using a pointed object such as the tip of a ball point pen. The LED on the remote blinks twice.
[2] Press (Setup) on the remote control handset itself.
[3] Enter "9981" using numeric keys. Once the remote control code is resetted sucessfully the remote control will blink twice. If reset is successfull, blink twice, if not sucessfull, will blink 6 times.
Nov 23, 2011 | Yamaha RXV567 Receiver
How to configure UET-606 Universal remote for NIKAI LCD TV?
Get the UET-606 Remote
1. Make sure its switched on
2. Point the UET-606 Remote towards the TV
3. Press the SET + TV button at the same time - the Red LED on Power will Illuminated solid Red
4. Press the SET Button again while still holding the TV button
5. the Power LED will begin to blink red
6 Enter the code 136
7. Press the Red Power button several times [sometimes 60 times] until the TV set resets itself
8. if the TV resets itself - point the remote away from the TV set and press any button or the SET button until the Power LED stops blinking
9. you are now ready to go
Aug 20, 2011 | One For All URC 7740 Remote Control
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Dvd recorder TV Guide will not work.
Contact the vendor of TVGuide onscreen. They can help troubleshoot the issue. You an contact them at Macrovision CE Support <ce_customer_support@macrovision.com>
Dec 30, 2009 | Philips HDRW720 DVD Recorder
Philips DVR model HDRW720/17 Display screen shows "Blocked"
Do you have a disc locked up inside? I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Oct 30, 2008 | Philips HDRW720 DVD Recorder
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Philips HDRW720 DVD Recorder Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
