Question about Pelonis Disc Furnace Heater
Where can I get a replacement air filter? - Pelonis Disc Furnace Heater
  • 384 Answers
Dear sir/madam
please try to search at near of your area on pelonis product,s dealer and then you can buy your air filter there.
hope answer the question
thank you
please vote!
Posted on Sep 29, 2010
Does hilux 2005 SR5. Have cabin filter
Go here so you can find out how to replace and or clean the filter .
https://www.youtube.com/watch?v=8zFIRHp-NS courtesy of youtube . https://www.youtube.com/watch?v=8zFIRHp-NS
Oct 22, 2017 | Cars & Trucks
Where is the air filter located inside a 2002 Mercury mountaineer
I don't know if you are talking about the engine air filter or the cabin air filter so I will try to cover both.
Engine Air Filter...
How To Replace Engine Air Filter 2002 10 For Explorer Mercury Mountaineer
The cabin air filter are basically the same on all / most Mercury/Ford Mid Sized SUV.
Cabin air filter replacement Mercury Mariner
Good luck,
Semper Fi.
Z
Jun 16, 2017 | Mercury Cars & Trucks
How to clean air filter?
Hi Sharon!
If you have a paper air filter it will need to be replaced, rather than cleaned.
However if you have a foam air filter you can wash it in mild detergent and allow it to completely air dry and put it back into your chainsaw.
Here is a video about how to replace the air filter on a chainsaw, most are pretty similar, so if it's not quite the same brand as yours, it should give you the general idea.
Best of luck!
Replacing the Air Filter on RedMax Chainsaw
Chainsaw Air Filters I've also included a page to find replacement air filters for your chainsaw!
Sep 27, 2015 | Garden
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Sep 26, 2011 | ViewSonic PJ551 Multimedia Projector
How do I change the filter on my CP S335 projector. It is saying no air flow.
WARNING ?Before caring, make sure the power switch is off and the
power cable is not plugged in, then allow the projector to cool sufficiently. The
care in a high temperature state of the projector could cause a burn and/or
malfunction to the projector.
?Use only the air filter of the specified type. Do not use the projector with the
air filter and filter cover removed.
?Avoid wetting the projector or inserting liquids in the projector. It could result
in a fire, an electric shock, and and/or malfunction to the projector.
CAUTION ?Please replace the air filter when it is damaged or too soiled,
and also when you replace the lamp.When the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the air filter becomes clogged by dust or the like, internal temperatures rise and the power may be automatically turned off for malfunction prevention.
1. Turn the projector off, and unplug the power cord. Allow the projector to cool for at least 45 minutes and prepare a vacuum cleaner.
2. After making sure that the projector is cool adequately, slowly turn the projector so that the lens-side is facing up. Please be careful for a projector not to fall. While the projector is placed lens-side up, hold the projector.
3. Putting a finger on the filter cover's knob, slide the filter cover in the direction of the arrow to remove it.
4. Holding the air filter's knob, pull the air filter off.
5. Apply a vacuum cleaner to the vent of the projector for the air filter. And then slowly turn the projector bottom up.
6. Apply a vacuum cleaner to the air filter and filter cover.
Please replace the air filter when it is damaged or too soiled.
To prepare a new air filter, contact your dealer and tell the air filter type number = NJ09702.
An air filter of specified type will come even with the replacement lamp for this projector.
7. Position the cleaned air filter or a new air filter into place, and push the points
of "PUSH" word with claws to fix the air filter.
8. Replace the filter cover and snap it back into place.
9. Slowly turn the projector so that the top is facing up.
10. Turn the projector on, and reset the filter time using the FILTER TIME
function of OPTION menu (?37).
NOTE • Incorrectly resetting of the filter timer (resetting without replacement,
or neglect of resetting after replacement) will result in incorrect message
functions.
Jan 03, 2011 | Hitachi CP-S335 Multimedia Projector
My hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
Jan 14, 2010 | Hitachi CP-X201 Projector
Its time to replace my air filter.
Inspect/Replace As a filter gets dirty, the amount of air that can flow through it is reduced. This is not a problem until less air than the engine needs gets through the filter. Without the proper amount of air, the engine will not be able to produce the power it should, nor will it be as fuel efficient as it should be.
Included in the preventative maintenance plan for all vehicles is the periodic replacement of the air filter. This mileage or time interval is based on normal vehicle operation. If the vehicle is used or has been used in heavy dust, the life of the filter is shorter.
Always use a replacement filter that is the same size and shape as the original.
The shape and size of the air filter element depends on its housing; the filter must be the correct size for the housing or dirt will be drawn into the engine. On today's engines, air filters are either flat or round.
fr_12.06.3184.gif Typical flat air filter element. f12-07.gif Typical round air filter for a late-model vehicle. Courtesy of Ford Motor Company. When replacing the filter element, carefully remove all dirt from inside of the housing. Large pieces of dirt and stones may accumulate there. It would be disastrous if that dirt got into the cylinders. Also make sure the air cleaner housing is properly aligned and closed around the filter to ensure good airflow of clean air.
(i searched this info on autozone.com)
Apr 27, 2009 | 1995 Oldsmobile Aurora
How many air filters in my 2005 Honda Odyssey?
Your Honda Odyssey comes with only 2 filters: an engine intake air filter and a cabin filter.
To learn how to change your own cabin air filter, see my posting on youtube:
Apr 03, 2009 | 2005 Honda Odyssey
Difference between an Air Filter and Air Conditioning filter
The air conditioning filter that your manual speaks of is known as a ''cabin filter'', it is much differant then your engine air filter. It filters the incoming air into your vehicles interior. So if someone has told you to replace your ''air filter'' they are more then likely speaking of your ''engine'' air fitler. You should check your engine air filter every oil change. If it shows signs of dirt, then replace it. Hope this helps =)
Mar 12, 2009 | 2003 Toyota Land Cruiser
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Pelonis Disc Furnace Heater Logo
433 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
