Question about Emerson Dryers
Vintage emerson electric table fan started making high pitched noise and now the blades will not turn. Even off I can't get them to rotate freely. It has never been serviced or oiled.
    Sergeant:
  • 270 Answers
The motors on ALL fans have a shaft going thru the motor which turns as a result of the pulsation of AC current.
The shaft is maintained in the center of the motor but alas parts wear out. Metal on metal (the squeaking sound) indicates the parts are wearing.
The stopping (seizing) of the fan blades indicates that any movement of the shaft is no longer possible due to friction.
As repair, a technician could keep the casing and install a new motor.
good luck and don't forget to vote!!!
Posted on Sep 29, 2010
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Why doesn't my fan rotate anymore?
definitely sounds mechanical. try prying open the motor area and see if anything happens when you turn it on. i'm guessing it might be a short somewhere that's making the other parts have to compensate
also check into servos, relays, and whatnot
May 15, 2015 | Miscellaneous
Fan makes knocking noise INSIDE like a clunk clunk. even with it turned off and the AC register blowing right on it (and making it rotate), it STILL makes the noise. so it isn't electric in nature (i...
Maybe the blades are hitting somewhere when it is rotating, otherwise, it could be bad bearings. Is it a store brand (Hampton Bay,Harbor Breeze or hunter fan sold in box stores)?
Aug 07, 2013 | Dryers
Noise
This fan isn't even worth fixing! When you're buying a fan,look for blade pitch or CFM's. Don't buy anything under a 12 degree blade pitch. 14 degree pitch would be better. Remember, you get what you pay for!
May 26, 2013 | Westinghouse Contempra Trio 42" Ceiling...
Shaver is fully charged. all 3 drive shafts rotate as they should with the shaver head open. with the shaver head closed, no rotation and I hear a high pitched tone.I can rotate the cutter clades manually...
something is jamming the heads from turning. the high pitched sound is the motor trying to turn but cant. if you are certain tht ll 3 blades turn freely inside their combs, the problem must be with he retainer that holds the blades into th frame. there are metal pieces on there that can get bent and interfere with the blades. If your retainer is damaged, you can get a new one at shaveroutlet.com
Jan 12, 2010 | Norelco 7800XLCC Electric Shaver
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
High Pitched noise
I had a high pitch noise, didn't sound like it came from the "underside". Turns out it was one of fans that had little chips in the blades? My Audi dealer replaced it, and it's fine now.
Jul 28, 2008 | 2002 Audi A4
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
Noise
Turn of the circuit breaker before doing this or plug out the power cord..
- check if the fan motor is not stuck up by touching the fan blade by your finger if it rotate freely. If stuck up full out the fan motor and put a little oil and rotate it manually until it turns freely.
- Check and rotate the fan blade manually and be sure that it is not mis align and not touching the fan blade frame.
- Check for loose bolts and screws that cause the fan motor vibration.
- Check for foreign object that obstructing the rotation of the fan motor.
- Check for defective bearing or bushing.
Jan 03, 2008 | Samsung RS2556 Side by Side Refrigerator
Dryers Logo
366 people viewed this question
Top Emerson Dryers Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jim Thurston
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerson Dryer Expert? Answer questions, earn points and help others
