Question about HP DeskJet 670c InkJet Printer
Sound My speakers aren't working when I turn them up all the way. I tried to go to the control panel but it says there is no device installed. HELP!!!
    Sergeant:
    Champion:
  • 341 Answers
Your speaker is NOT a device that the computer can detect. You got a bad sound device problem. Check your motherboard's site for support (for built-in sound card). You might need to reinstall the sound card drivers. Try to check in the "Device manager". You must have the sound device installed before sound can be heard from the speakers :-)
Posted on Sep 24, 2008
There is no sound in my pc
Some possiblities are:
* The sound is muted or turned down to zero. (This can often be controlled from the keyboard; for Windows 7, try the control panel > sound > adjust system volume).
* Speakers aren't connected, are turned off or are set to zero volume.
* Speakers are broken (least likely).
May 09, 2012 | Dell Latitude D610 Notebook
They worked for a long time, now all the sudden they aren't working. The main speaker it's powered on; however the green light is no longer lit and no sound is coming from them. Checking the...
possibly corrupted or missing sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 29, 2011 | Altec Lansing ACS 54 Computer Speakers
Hi i have logitech x350 5.1 speakers, but when ive plugged them in they aren't working and in the control panel it says there is no audio device. what am i doing wrong?
When you are looking in "control panel", are you looking at "sound, audio and game controllers"?
To access that you will need to get into "device manager" and ckick on the box next to "sound, audio and game controllers". After you click on the box, you should have a list of your audio device(S). Right click on eqch one, on at a time and you should see "disable", If you see "enable", click on that. While you are looking at your device(s), what do you see, ie, Realtek, Soundblaster, etc, for you sound software. Depending on what you have, you may want to make sure you software is updated. I will start you off with these things to try, if this doesn't solve your problem or, if you have other questions, let me know.
Dave
Aug 21, 2011 | Logitech X-530 Computer Speakers
Good morning -- I am having an issue with my volume - I have it on the highest possible, but my speakers aren't able to pick up much still
Does any sound at all come out of your speakers?
1. Go to Start > Control Panel > Sounds and Audio Devices
2. Under the volume tab, turn your "Device Volume" bar up
3. Also, click on "Speaker Volume" at the bottom and adjust both left and right speaker bars up
Jul 20, 2011 | HP Compaq Presario SR1920NX PC Desktop
My speakers just for some unknown reason aren't working.The remote control won't light up anymore
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
if you don't have the drivers you will need to download them
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
Jun 29, 2011 | Creative Labs Inspire T3030 Computer...
I rebooted my computer,& now my speakers aren't givng out any sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 23, 2011 | Altec Lansing VS2120 2-PC SPEAKER SYSTEM...
Speakers are no longer working. I had a virus that was taken care of by one of your support people. The virus made it impossible for Windows to open. Now my speakers don't work. They are plugged in and I...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Feb 07, 2011 | Dell A215 Computer Speakers
I am trying to turn on my radio on the computer but i'm not getting any sound. please help!
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 11, 2010 | Dell AS500 Sound Bar Computer Speakers
My computer speakers won't work. There is no sound. They will turn on, but no sound is coming out of either speaker. I tried all the windows help but nothing worked.
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 06, 2010 | Gateway G-MAX2000 2-Piece Multimedia...
Speakers
make sure the settings are set for speaker use in the Sounds and Audio Devices under Control Panel. also check that it's using your sound device driver installed.
Jun 26, 2008 | Audio Players & Recorders
HP DeskJet 670c InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
