Question about Nokia E75 Cell Phone
My nokia e75 is completely dead. it refuses to go on even when a new battery is put in or when it is connected to a charger. it didnt fall or get wet. it just started having software issues then died. what can i do to fix?
    President:
  • Nokia Master
  • 1,932 Answers
Please go to nearby NOKIA CARE they will reinstall the software and the mobile will be fine
Thank You
Posted on Sep 29, 2010
I own a 1999 Toyota 4Runner 4 cylinder, SR5. I had my drive shaft replaced and the battery went dead while my truck was in the shop. The repair man put my battery on a charger and i was able to start my...
Please visually check your battery. If top of the battery is surrounded with blackish material, or it is used for more than two years, probably it is dead. If not, then get the specific gravity of the battery be checked. It is supposed to be in between 1.280 - 1.320 at the temperature of 40 degree Celsius. If the specific gravity is found low it needs to be re-charged for nineteen to twenty two hours at the rate of slow charging.
Regards,
Shadab Lodh
Feb 03, 2013 | 1994 Toyota 4Runner
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
2006 Street Bob wont start even with a charger on. Only clicks.
Hi Tony, first when checking anything in the starter circuit you must make sure the battery connections are clean and tight especially the negative cable at both ends and has a 12.5 volt or better charge. It must not fall below 9 volts during the cranking procedure with a volt meter hooked up. If it does fall below 9 volts do a proper load test on the battery and replace if necessary. Second replace the starter relay cheap $6 and make sure it's well grounded and getting 11.5 volts or better to activate. Third remove the back cover of the solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. If it still chatters replace the solenoid. Good luck
Nov 26, 2011 | 2006 Harley Davidson FXDBI Street Bob
My fone dead put charger in does nothing dead dead dead
Nokia phones are notorious for slow response time when recharging from a completely dead battery.
Remove battery.
Make sure there is good contact between all of the contact points.
Replace battery.
plug in charger.
wait for at least 5 min.
If recharge symbol does not appear in window, then one of these things has occurred:
1. Phone has internal damage or water damage. no way to fix without nokia service.
2. Battery is dead. Try a new battery
3. Charger is bad. Try a new/different car charger or home charger.
These chargers are very inexpensive on Craigs List, try to solve it before throwing away the phone. Good luck,
A former Nokia employee.
Feb 16, 2011 | Nokia Cell Phones
I have a E75 handset since Oct 2009.I am facing aproblem since this morning that the phone is hanging ( screen not responding and does not take connection).I removed battery couple of times to check..still...
If your phone not responding, I think you should reset your phone. But before you do this, make sure you have put off your SIM and memory card from the phone, and make a back up of your data.
There are three steps of resetting the phone :
Nokia E75 Soft Reset:
This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) nor applications from a third party. Key Code *#7780# (click this combination of keys on the keyboard in the mobile)
Nokia E75 Hard Reset:
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory card. Key Code *#7370# (click this combination of keys on the keyboard in the mobile)
You can also achieve Total Reset by pressing and holding down following keys: * + 3 + Green Button (call) immediately after turning the mobile on.
Note: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset, the mobile stop receiving electricity it can ruin the internal flash memory of the mobile device and stop function.
Or you can check this sites :
http://anythingnokia.com/nokia-tips/nokia-e75-full-reset-soft-reset-and-hard-reset/
http://discussions.europe.nokia.com/t5/Eseries-and-Communicators/Reset-E75-using-7370/m-p/540002
Hope this help and be kind to rate this answer, thank you.
(^_^)
Jan 07, 2011 | Nokia E75 Cell Phone
Hello i need master code for nokia E75 p help me
NOKIA E75 falls under BB5 group..and its master code can't be generate by master generator.. but for this solution you can try it..
Nokia BB5 Security mastercode reset
These newer BB5 phones require software to reset the security code:
Nokia 3250, Nokia 6125, Nokia 6131, Nokia 6270, Nokia 6280, Nokia 6630, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 7370, Nokia E50, Nokia E60, Nokia E61, Nokia E62, Nokia E70, Nokia N71, Nokia N72, Nokia N73, Nokia N80, Nokia N90, Nokia N91, Nokia N92, Nokia N93,
Nokia BB5 security code reset procedure:
* Connect your phone via USB cable in pc mode
Sep 04, 2010 | Nokia E75 Cell Phone
Nokia 6500 wont charge
Where you connect your charger there is a loose connection there,what i can tell you for your phone to stay alive is just buy an universal charger it is not expensive,you put your battery in then after charging replace it in your phone and the problem is solve .
Feb 09, 2010 | Nokia 6500 Classic Cellular Phone
Phone Not Turning on.
it's one of three problems, 1. your battery is completely fried and you need a new one. 2.your charger is fried and you need a new one 3. your charger port on the phone is broken and you need a new one. If it's number 3 I would just get a new phone as replacing it is a major hassle
Aug 06, 2007 | Motorola Mobility RAZR V3
Nokia E75 Cell Phone Logo
79 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
