Question about GE Profile PDW8600J Built-in Dishwasher
My GE Profile model PDW9280N00SS dishwasher is 3 years old, and has the SmartDispense feature. Over the last month or so, a noticeable amount of detergent is leaking into the dishwasher between cycles. The dispenser is not clogged, and it does not contain water at this point. I also exclusively use Cascade liquid detergent. What needs to be done to correct the leaking detergent?
SOURCE: GE Profile Dishwasher Not Cleaning
I removed the outer metal door cover by removing most of the phillips roundhead screws. The two screws closest to the latch should not be removed (they hold plastic pieces that help hold the outer door cover in place during reassembly), and the two flathead screws on the side of the door near the hinge should not be removed yet (they attach the pump). The door cover also has two small hex bolts on the bottom - these should be removed, too (or at least loosened). I removed them.
The outer door cover has two flat flexible wire bundles (for the buttons) that attach to the door using "quick-connect" push-pull connectors. One has a small tab which must be slightly depressed. Gently but firmly pull these out. Set the door cover aside.
I removed the pump by (one) gently but firmly removing the short (2" or so) gray rubber tube from the bottom of the detergent reservoir (NOTE: any detergent remaining in the reservoir will immediately drain on the floor at this time -- I let it drain most of the detergent into a cup, but then I taped a tapered wood screw into the opening to serve as a plug); (two) removing the 90 degree rubber fitting that attaches to the door; (three) disconnecting the motor wire electrical quick-connect; and (four) removing the two flathead screws that attach the pump to the door.
My (rotary peristaltic) pump has a black flexible tube that was clogged with solidified detergent. I verified the pump worked by first connecting the pump to power from the wall outlet. I used an old extension cord, cut the ends, crimped some small connectors that did not fit well to the pump connector, then taped the whole thing to help prevent a shock (I did not feel comfortable with this, but I did it anyway. Use caution. If I have to do it again, I would have used a pipe cleaner or wire instead of operating the pump as described below.). The pump motor is rated 110 volts ac., and the pump was operating fine. I think I got lucky (the pump spun the correct direction). It may be that if I reversed the wires, the pump might have operated backwards.
I then held the pump inlet hose under hot water in the sink for about 10-15 minutes, occasionally squeezing the hose, until the thick detergent had dissolved. During this time, the pump was pumping the water out the outlet.
I put everything back together, and the dishwasher cleans again.
Posted on May 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
Posted on Mar 27, 2009
ginko
  • 19396 Answers
SOURCE: GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Posted on Apr 06, 2009
  • 81 Answers
SOURCE: detergent dispenser doesn't empty completely
The detergent reservoir should pop open allowing the wash water to "wash" the detergent clean. It sounds like your DW is not "spraying" with full force. From your description, it sounds like your water pump is malfunctioning OR your drain is clogged with food and the water flow is restricted, because the wash water is the original rinse water from the first cycle and it recirculates. Check and make certain your drain is not clogged before you call the repairman or replace the machine.
Posted on Apr 24, 2009
I had this problem myself and the purge solution listed above did not work for me. There was just so much gelled and hardened junk in the dispenser container, it would have forever to clean out. Additionally, I think it could have had the chance of damaging the pump. Here is what I did instead:
* Remove power to the dishwasher (via circuit breaker or pull plug under sink).
* Take all dishes and bottom rack out of the dishwasher.
* Close dishwasher door.
* Remove bottom 2 screwbolts with a rachet.
* Open dishwasher door.
* Put a small box that is big enough to hold the panel while the door is opened.
* Remove screws holding inner door to outside panel. Don't remove the screws heading into side of door itself. Also, there are 2 screws near the latch that you don't want to take out...just loosen them and you'll see they don't behave like the other screws.
* The panel will separate from the door, BUT there are 2 ribbon cables connecting them. Have someone hold onto the door...so it won't pull up hard on the ribbon cables.
* GENTLY pull back and forth (side to side) on the white ribbon cable on the door. It will come off with a connector.
* Use a small flathead screwdriver to gently press the tab in on the blue connector and gently pull the blue ribbon cable straight out.
* Remove panel completely and put aside.
* Gently close dishwasher door. It will want to fly up since it doesn't weigh as much.
* Look for a red/green cable from the detergent container (detergent level sensor) and disconnect it.
* Open dishwasher door and take off detergent cap.
* Have someone hold onto the detergent container from the other side and un-twist the detergent locking ring (the item you normally screw the cap into). You can use your hands or put a cloth over it and gently remove with channellock pliers. The detergent container will now be free, but connected to a rubber tube that leads to the detergent dispenser pump. It will easily disconnect by pulling the container away from the tube/pump. The container is now free!
* Shake the living hell out of the detergent container over a trashcan. Mine had tons of white and blue gel in it. Once you remove most of the gunk, bring it under the faucet in the sink and rinse with warm/hot water. Shake, rinse, empty, shake, rinse, empty. The hole where the detergent comes out should be 100% cleaned out. Use the handle of a small paintbrush (or something) to push the hardened gunk out of the hole. Be sure the container is totally cleaned. Take your time on this.
* Put everything back in reverse order. The only thing I did differently is putting the door panel back on the door: Close door, reattach container & cable, bring over panel and re-attach ribbon cables, hang panel on the top two white plastic blocks that you loosened the 2 screws by the latch with earlier. Then screw on the bottom 2 door screws (do not tighten until all screws are put back in place). Put all screws back...don't overtighten.
* Re-apply power and you should see the 'Add detergent' light come on. That's a good sign!!!
* Put in fresh detergent and you should be good to go.
* Lesson learned: DON'T mix enzyme and bleach based detergent ever again!
This was easier than I thought it was going to be...and didn't waste electricity, water, or time based on the purging method. After all, if it is clogged, you can't purge it. Enjoy!
Posted on Jun 19, 2009
Ge dishwasher pdw9280n00ss
It is not very unusual to find 120V on the door panel. The voltage is fed straight to the control board from the mains from which it gets distributed to different components like door switch, detergent detector, motors and pumps. The layout is shown on this schematic
http://www.appliancepartspros.com/escutcheon-door-assembly-parts-for-ge-pdw9280n00ss.html
It is likely the door switch connection is leaking. You will need to take the multimeter (on ohms setting) and carefully measure the points on different components on the disassembled door panel for short to the panel body. Make sure the dishwasher is disconnected from the mains power.
Apr 20, 2014 | GE Dishwashers
Replace rubber seal
You don't give the complete model number. If you are referring to the tub gasket that surrounds the opening (on three sides) when the door is lowered, it is held by friction in its groove. If it doesn't stay in place when fully pressed in, replace it with (most likely) WD08X10032.
Nov 08, 2013 | General Electric PDWT380VSS GE Profile...
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
The pump on my GE Profile dishwasher is not draining.
If it is the last cycle only it is not the pump. It is a wiring or timer issue. Most likely the timer.
Nov 11, 2009 | GE Profile PDW8400J Built-in Dishwasher
Apr 06, 2009 | Dishwashers
Rotating arms getting clogged very frequently
I do not have a huge amount of information about the GE Profile PWD7880 handy, so I don't know if it has a chopper blade/food disposer at the bottom of your Dishwasher, but when a dishwasher gets the holes of the spray arm, the most common cause is the chopper blade is jammed/blocked. Then the food debris never gets sliced and diced at the end of the of each wash cycle.
Opening up the filter under the spray arm, removing as much of the lower assembly and inspecting every where in the sump area, especially the drain pump area would be a great beginning.
Good Luck! Just ask if you have more questions.
Apr 04, 2009 | GE 24 in. Profile PDW7800 Built-in...
Mar 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Need a diagram for the kenmore dishwasher model 665.16645890
I have GE Dishwasher (model no:GSD1100G02),and for the last few month I was not able close the main detergent cup cap(it is coming back to full open position,even after keeping the CAP turned all the way to a closing postion)
I have called the GE spare parts division,and obtained the New detergent cup cap,and when I tried to remove the old one,inorder to replace with the new one,I was not able remove old one.
Please help me how to remove the old main detergent cup cap,and replace with a new one.
Hope I will hear from you soon in this regard.
Murthy Pillutla
Home Ph:630-428-3277
Cell:484-919-3653
Jun 14, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile PDW8600J Built-in Dishwasher Logo
573 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
