Question about Nikon F3HP 35mm SLR Camera
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i reset the film counter?
  • 169 Answers
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Posted on Sep 29, 2010
The film wont roll out as i take pictures
Are you sure the film is attached to the take-up spool ?
Sep 13, 2017 | Pentax K1000 35mm SLR Camera
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
I have an old Nikon FG 35mm Camera that I haven't used for a long time. It worked fine when I put it away, however now after loading new batteries and film, I can't ****/reopen the shutter, film doesn't...
Were the old batteries left in when you stored it? Alkaline cells can leak and cause corrosion, no matter what anyone says. A coating of metal salts on the battery contacts could be the problem. I hesitate to suggest that you may have put the cells in the wrong way up, or forgotten where the on/off switch is, but these will certainly stop the cameras working.
Nov 18, 2010 | Nikon F3 35mm Film Camera
My camera won't load film
Set your lens to the smallest aperture ( largest number on lens ) f/22 or f/32 and lock it in place with the small latch on the aperture ring. The camera won't operate in auto modes without the lens set there.
Oct 21, 2008 | Nikon F65 35mm SLR Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Nikon FM: Shutter release button will not allow me to take another photo and I'm only on frame 15 of a roll of 24. The film advance lever does not move the film, but it does open all the way to the right...
The FM is a mechanical camera, the batteries only power the metering system. Sometimes what happens is when you buy film say in 4 roll packages, they give you 3 24 exps and a 12 exp. I suggest that you rewind the roll and check this. You will only lose the last frames if the roll is indeed a 24 exp.
Jun 08, 2008 | Nikon Cameras
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Nikon F3HP 35mm SLR Camera Logo
178 people viewed this question
Top Nikon Photography Experts
Bart Pulverman
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
