The screen is black,on startup it reads no signal/no input.moved monitor to another cpu..works fine
  • 506 Answers
If the Video card is onboard, disable it and insert a PCI video card.
Posted on Sep 29, 2010
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
NO SIGNAL INPUT - message
Hi Rick,
Most common cause of this error is when the video signal cables are knocked off rendering the connection from the monitor to the CPU loose. Turn off the PC and secure all connections. Have you had your computer moved or repaired where you need to remove connections? Some PCs have more than one video cards (video output) and you may have connected it in the wrong video port. You can isolate the problem further by connecting your CPU to a known working monitor (office, freind's, neighbor, 2nd home PC). The other way is to isolate the problem is to connect your problematic monitor to a known working PC and see if video will be displayed. If video is present, your CPU's video card has gone bad or the contacts are not seated properly in the slot. Best Regards
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
