Question about Whirlpool Washing Machines
Starts agitating as soon as cycle is started. Does not start to fill with water like it is supposed to
  • Whirlpool Master
  • 8,220 Answers
You could try to remove the bottom panel and clean out the pump housing. The tech sheet is in there. You could consult it.starts agitating as soon as cycle is started. - cd71714.jpg2aa4f27.jpg
Posted on Sep 29, 2010
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Machine fills up with water then when its suppose to agitate it just stops working will turn timer & push knob in & out & reset then it will work
How long do you let it sit after the water fills up, somtimes the timer will take a little extra time to get to the point that starts the agitation cycle.
When it dose this, without pulling the knob out, turn the disk on the timer clockwise 1 click and see if it starts up agitating, if it dose dont worry about it it is normal
Nov 09, 2009 | Maytag PAV2300 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
May 17, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
