Question about Dell Inspiron 1501 Notebook
Hi. Problem with Dell Inspiron 1501 Model No PP23LA. I blundered into using the Operating reinstallation dvd & ended up deleting all partitions & installing XP media centre edition all over again, installing drivers & utilities disk but it's not the same as the factory image should look. Now how do I get the original factory restore image partition back on my friends 1501? Their must be a ghost disk from dell which they can ship out to me that just restores it to factory. Because now I have done it the old fashioned oem pc builders way, it's not the same as dells configuration. I only have c: partition with windows. Is there anywhere where I can purchase an Image disk which will put everything right factory perfect please?
    Guru:
  • 1,481 Answers
NO....
disk supplied by Dell will only help you restore in an emergency....that too if your system is enabled the restore option...before your blunder....
i suggest you re-do the full PC as per my adivse....
first u must make a backup of your critical data if u have any on ur pc on DVD disks....DONT use pendrive...
since ur laptop is in working condition u can do the following in this laptop itself....else u may have to use another PC....
1st go to my shared drive (link below) and download this application....
http://www.4shared.com/file/gTU7Zdj3/boot-cd-iso.html
this is a rar file, unzip this file with winrar....the folder that winzip will create will have a self burn software called "ISO-Burner"
insert a blank CD in the drive (i guess ur laptop has a CD/DVD writer) else u will need another PC to write a CD....
click on the ISO-Burner, it's a self create burn application...it will create a bootable CD with the needed applications....
to wipe ur disk....clean...
.... u must ensure that the CD drive is the 1st boot drive in BIOS ( i guess u know how to do it)
keep the boot cd in the CD drive...switch off and switch on again...and let it boot from the CD....wait...wait...
it will boot and load an application that will have some tools to make the disk factory fit....
select application KILLDISK...on the left panel...select F10 to wipe your disk clean....type in ..."erase-my-data"....and wait...wait...
the process will take aprox 5 hrs for a 100 gb disk....wait and have patience....so if you HD is 200 gb it will be more than 11 hrs to finish....
once done you can replace the cd with the WinXP disk, make partitions, format and create different drives as per you needs and make you machine as good as new...
for more info on how to format and use WinXP pls visit my site
www.sureshayyar.110mb.com
pls revert back and leave a feedback and rating for the solution....it will help me become a "Guru" here on Fixya....
all the best
regards....
Posted on Sep 29, 2010
I'm trying to restore my Dell Inspiron 5160 to the factory settings
If the restore partition is still there, press F8 just before boot and select restore. You will lose all data and programmes will need to be reinstalled.
Feb 09, 2015 | Dell Inspiron 5160 Notebook
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power...
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
May 19, 2011 | Dell Inspiron 1501 Notebook
I had new dell inspiron 1501 laptop with windows 7 os instaled in 350gb singel drive and i want to saparet two or more parteshens with out OS loss
if your hard disk is only 1 partition right now, reformatting the hard disk, then deleting the current partition and creating additional partitions is the way to do it. This means, you also have to reinstall Windows. if you do not want to reinstall Windows, look for programs like partition magic or the like that can allow you to create additional partitions, though, there are cases this may have issues later.
Sep 03, 2010 | Dell Inspiron® 1501 (N11157) PC Notebook
I am trying to use the pc restore. to reformat my pc
You should try pressing F12 alone to get to the boot options menu, there you can select to boot from your restore cd.
Let us know
Good luck
Apr 15, 2009 | Dell Inspiron 1501 Notebook
Trying to restore Dell Inspiron 1501 to factory settings.
don't hit ctrl, f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive (usually the D: drive) good luck.
http://virusremoval.vpweb.com
New York
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 laptop serious problem
Hi
Please follow this this thread. Its for the Inspiron 1000 but the steps are all the same for the inspiron 1501.
http://www.fixya.com/support/t1498433-dell_laptop_inspiron_1000
To reinstall the drivers please read the driver reinstallation guide
and this will help you as well.
Step by step instructions on how to install the OS and then install the drivers as well.
http://tinyurl.com/636evy
Post back if you still need help.
Thank you
Rakesh
Dell Laptop Expert
Jan 10, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
554 people viewed this question
Alun Cox
