Question about DFI LANPARTY UT nF4 SLI-D Motherboard
OK It started when i exchanged my CPU , Athlon 64, 3200+ with Athlon x2 4200+. For anybodys best guess thing should work from get go - but it didn't ofc...Three red leds , no post and a long beep. Ok i came online looked for solutions, reseted the BIOS ( short altho). No go whatsoever... Now fun ( not really ) part...Ok i gave up, went to install my old CPU inside - and guess what - same error message... Could faulty CPU burn MBO? No way..Esp when its not the CPU error, its MEM error ( long beep)... Any ideas.. post or mail plz
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: dfi wt70ec socket 423 board never used and visiontekx1300512mb agp
Either video adapter is not seated properly. Remove the video card & reseat.
Also, check to ensure the monitor cable is connected properly.
Posted on Jan 01, 2008
  • 298 Answers
SOURCE: No Post
If your getting led lights on your board but no post or no beeps. This is usually a fried processor. Sometimes motherboards have diagnostic leds on them. If this is the case, then open you owners manual and diagnose the failure by reading the leds when the motherboard turns on.
Posted on Mar 05, 2008
  • 76 Answers
SOURCE: my dfi mini itx MI
seems like your motherboard has burn out, you should get new one.
Posted on Apr 07, 2011
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
HP Pavilion d4000 (d4495.se-a) cant find or see the USB ports, have reinstalled XP home, new backupbattery, check with Pd-doctor 3.0 -result test 4 CPU processor test, CPU Number 2 (Apic ID 01H) CPU...
You could easily pick up an aftermarket USB PCI card, which will give you 2-4 USB ports that have their own logic chip. These are quite easy to install and very inexpensive.
Another option would be a front-mounted USB hub, which would attach to the USB header on your mainboard. They come in 3.5" size (to go in a floppy drive slot) or 5.25" for CD/DVD size slots.
Either of these should work fine as long as the rest of the PC is OK. If not, they are pretty much universal, so you could put in your next computer. (if it didn't work).
Jun 30, 2012 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
Is AMD Athlon X2 7850 supported by a foxconn 6100M2MA-RSH2 mother borad?
This is a list of compatable CPU's for your motherboard.
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20AM2&model=6100M2MA-RS2H&cputype=AMD
Also you can search your board to CPU here;
I don't have your exact model so if you do, and it shows in the list, you're good. My best guess would be taht it would work.
May 12, 2011 | Computers & Internet
I have an Asus M4A88T-M Motherboard, AMD Athlon x2 3.10Ghz (255 series) 2Gb kingston DDR3 ram 1333Mhz. All was working great untill one day I got home and switched it on and a red LED started flashing! I...
please tell us if there are any beep or no try to take off the ram and listen is hear any sound , finaly if didn't hear any sound that mean one of three
1- bios need to programed 80%
2- cpu is damaged 5%
3- mother board is damaged 15
if you see that is helpful please don't forget to vote me
best regards
Apr 24, 2011 | Computers & Internet
Swapped a AMD Athlon MMX for a AMD Athlon XP2800 but get no joy
HI..........
just load a new bios and enable the cpu from the bios window
Nov 15, 2008 | AMD Computers & Internet
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Motherboard Issue
Hi Tomokato,
This maybe nothing but the first thing I checked is the CPU.
Supported CPU list through Asus web site for M2N-SLI
(Click on this link). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M2N-SLI
The first supported 64 X2 is;
Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2
Second CPU supported;
Athlon 64 X2 3600+ (DD),1MB,65W,rev.G,SocketAM2
The CPU that you are using is not supported.
Since this is a new CPU, you might be able to exchange it for the Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2.
Link to Asus main web site for M2N-SLI.
http://support.asus.com/download/download.aspx?modelname=M2N-SLI&SLanguage=en-us
Suggest you add the above link to you're favorites.
Even you're memory is not supported. As seen in user manual page. 2-13.
Have more questions, feel free to ask.
Mike
May 01, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
DFI LANPARTY UT nF4 SLI-D Motherboard Logo
27 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
