Question about Gateway MX6920 Notebook
Error message on boot up
Dialog window pops up while desktop screen appears, before wireless connection is completed "Printer Card Transfer Monitor" need to shut down. No help or options to repair, yes , no, cancel, or o.k. just "X" or "close". Do you have any idea how to resolve this issue?
Hey, thanks for your reply. My printer is a Lexmark 5000 series. I did remove the printer software from my computer (Windows XP) . I reloaded the software and during the install, I got the same error message. There must be a problem with the software, but I have no idea what it is. I contacted Lexmark and they sent me to a website to get the latest drivers. This still did not fix the problem. Guess I'll toss this printer and go buy a different brand. I hate a company that can't support their own products....and it IS their problem.
Posted on Jun 10, 2008
    Sergeant:
  • 458 Answers
I do not understand your question. You did not even give me the kind of printer that this was. Try reloading your printer drivers and clear anything that you have tried to print from the printer.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Posted on Jun 04, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you try what I told you to do? I will still help you, but you need to tell me what you have done.
3 Suggested Answers
SOURCE: printer problem
You have asked this same question under a different name several times or you are copying someones question. Please do not do this and clarify your question. Asking a question several times by a different name is only going to clog the FIXYA system.
You have not given enough information for this to be solved. What O.S. is this? Have you tried to install the drivers again and have you updated the drivers? What kind of printer is this? Make and model number.
SOURCE: Error message after start up of Gateway Laptop
Neither of you have given the Printer Make and Model number. We can not help without this. This seems to be going around in circles on the board and asked different ways by different people. I have seen this at least 3 times now.
Can't set HP LaserJet Pro 400 as default printer
I recently had a troubleshooting appointment for an hp printer that could not be set as the default printer. When I tried to make it the default, a message box came up saying "operation could not be completed error (0x00000709)". Other than that, it seemed to work fine. I even removed all the printer software through "Programs And Features"in the Windows control panel followed up by a Windows system registry scan. I then performed a clean install of the hp printer still no joy.
Next, I began to research the "operation could not be completed error (0x00000709)" error message on the internet. I came across a variety of solutions, which I tried in succession with no luck. I finally discovered the one that worked. It was a simple fix to the Windows system registry. This is what I did to solve the annoying little problem:
I. Type "regedit" followed by the enter key in the "search program and files" text box in the pop up menu that appears after clicking the Windows"start button" in the lower left hand corner of the Windows desktop screen.
II. Next, click "HKEY_CURRENT_USER" in the left hand pane of the Windows registry editor.
III. Then click "Software" followed by "Microsoft" and next "Windows NT".
IV. While under the "Windows NT" entry, click "CurrentVersion" and then "Windows".
V. Now, one of the entries you should see in the right hand pane is"Device". If the value for "Device" as noted under the "Data" area is anything other than the printer you are using, then highlight "Device" in the right hand pane with the mouse and press the delete key to remove it.
VI. Restart the computer so it starts with the altered Windows system registry.
After the Windows desktop appears again, you should be able to go into the"Printers" area and designate your printer as the default without receiving the "operation could not be completed error (0x00000709)" message.
Being able to designate the default printer can save you a fair amount of work over the long run. This is because you won't have to specify your destination printer in the printer dialog box - it is already selected since it's been set as the default.
Mar 14, 2014 | HP LaserJet Office Equipment & Supplies
Tip
How to Configure a Wireless Printer Wireless printers typically come with a...
Wireless printers typically come with a transmitter that a laptop, with a wireless adapter, can connect to and print from any location in a home. In order to configure a wireless printer you will need to install the drivers and software from the installation CD that came with the printer. You will be able to run the configuration for the printer driver, for the laptop, at the end of the software installation.
  1. Insert the installation disc for your wireless printer into the drive on your laptop computer.
  2. Wait for the Installation Wizard to appear.
  3. Click the "Next" button to continue and go through each screen to install the software for the printer.
  4. Select the option to "Configure printer driver now" on the last screen of the Installation Wizard.
  5. Click the "OK" button when the Information dialog box appears.
  6. Select the printer port for your printer when the Printer Port Setup dialog box appears.
  7. Click the "OK" button when the "addport" dialog box appears.
  8. Click the "Next" button to continue.
  9. Select your wireless printer from the list of installed printers when the Add Printer Wizard window appears.
  10. Click the "Next" button to continue.
  11. Click the "Connect" button when the Configure Printer Port dialog box appears.
  12. Wait for a connection to be made with the wireless printer and then click the "Finish" button to exit the Add Printer Wizard dialog box.
  13. Repeat this process on each computer that you want to connect to the wireless printer.
on Apr 02, 2010 | Computers & Internet
Dell Pc won't boot gets black screen with floating dialog box
Floating dialog box is the monitor's self test. Your monitor tests good. Your computer is the problem.
Mar 04, 2013 | Dell Dimension 3100 PC Desktop
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
At boot time appears message 'Device Monitor Appliaction (mispell
try this:
1. download combofix and follow his steps (don not agree with recovery console)
link is here : http://www.combofixdownload.com/
notify me if problem is resolved
Jun 28, 2009 | HP Computers & Internet
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
I have just set up new desktop Acer. Error message: No input signal.
check the website for drivers. But it seems to me that there is another problem most computer boot up no matter what screen is hook up. have you tried any other monitors ? If you have and the work im not sure what your issue is but i would say that most likely if another monitor works that it is the monitor but if none of them work it is a graphic card issue. If you could let me know what you are running and i can help more i.e what window's and what type of graphics card you are using
Oct 26, 2008 | Acer Aspire™ T180 PC Desktop
Printer problem
Jun 02, 2008 | Gateway MX6920 Notebook
Installed WMP54GS and am getting the following error from Linksys Wireless Network Monitor Access violation at address 0040744D in module WMP54GSv1_1.exe'. Read of address 00000368
Possibly you have installed the WLAN monitor also that is why it is creating the error...try these settings... Reboot your computer in SafeModeUninstall the software for the Adapter from start >> All programs/Remove the Drivers from Device Manager...Turn your computer Off and connect the adapter in a different PCI Slot...Reboot your computer in Normal Mode...
>> Insert the Setup CD in the cd drive>> Click on Exit when the
Linksys welcome screen appears>>Click on start. Unplug & replug adapter ...>> There should be a "" Found New Hardware Wizard ""
that pops up on your screen>> Click on “Install software
automatically “, and then click on next. Once the installation is
complete>> Right click on the wireless network connection icon in the
system tray besides the clock >>Click on view wireless networks and
then connect to your network name...
May 01, 2008 | Computers & Internet
Apr 26, 2008 | Gateway MX6920 Notebook
Gateway MX6920 Notebook Logo
137 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
