Question about Canon PowerShot A560 Digital Camera
SCN Mode on Canon A560
When I switch to SCN mode, I get either AUTO or Movie mode, and the special scene modes that are supposed to be activated by pressing the FUNC./SET button in this mode do not activate.
  • alpinemonkey Aug 12, 2008
    I have EXACTLY the same problem. No access to SCN mode, it just gives me AUTO or Movie mode instead! All else on the camera works perfect.
  • Anonymous Sep 01, 2008
    Even me! I have the same problem! No special Scenes, only Auto...
  • 4 Answers
Actually it's an internal software issue. I have the exact same problem. The camera needs to be sent back to Canon to be repaired.
Go to Canon's website and follow appropriate prompts to get an email to customer support about the issue. They'll get right back to you and even provide free shipping to get it to them to service.
Posted on May 04, 2010
I have the same problem...BUT... if you move the wheel softly between SCN and indoor you get SCN =S .... the selector wheel fails, so i think it's a matter of warranty ×.×
maybe a manufacture defect, i have this camera for less than six months =s
Posted on Sep 09, 2008
Posted on Sep 01, 2008
It confused me too. Just go to SCN and hit the function.Set button (the little round button). It brings up a menu and you can switch left or right with the menu controls.
My polaroid iS2132 won't change settings when I turn the mode dial/Can't set the intelligent scene mode.
When you put the Mode dail to the SCN mode, It will enter the last used Scene mode. THEN press the MENU button to select other scene mode.
Don't turn any dail. Use the navigation controls left and right from the OK button, to move through the section. Press OK button to save and activate the selected scene mode.
Nov 17, 2013 | Polaroid IS2132-BLACK 16MP 21X Zoom...
Canon g12 problemsI recently recharged the battery. I have lost my landscape mode on setting scn, it has been replace with smart shutter mode. How can I get my landscape mode back.
you may need to adjust the scene mode by turning the knob to scn you may check out the manual through this link turn to page 3
Jul 15, 2013 | Cannon Cameras
How do i recover lost scene modes on canon powershot a470?
Turn the mode dial to "SCN", press the FUNC/SET button, use cursor-up/down to select the top icon along the left, then use cursor-left/right to select the desired mode.
Jun 21, 2012 | Canon PowerShot A470 Digital Camera
Where is the SCN mode on a canon rebel xsi
There are some scene modes available in the Basic Zone. Simply turn the mode dial on the top of the camera to the desired mode.
Full details are in the "Basic Shooting and Image Playback" section of the manual (beginning on page 43 in my copy). If you need a copy of the manual, you may download one here.
Mar 06, 2012 | Canon EOS Rebel XSi Digital Camera
How do you take continuous shots? I set it on the setting that says continuous shots but it only takes one picture. My friends also does the same
Continuous shooting is not available in the full Auto mode. You must select Manual mode (the camera silhouette with the M on it), or move the switch to the SCN (selected scene) position.
Sep 17, 2009 | Canon IXUS 860 IS Digital Camera
Canon A560 command dial skips auto scene mode
I had the same problem with my A560.If you are handy you can repair it yourself.Remove the seven screws from the camera.Note the hidden longer screw behind the battery door.gently remove the front cover first then the rear.note the place where the screw was behind the door has a slight overlap and will need to be pulled away to clear the corner (watch for the lens o-ring seal).The selector wheel has become misaligned between the contacts.unplug the ribbon for the wheel on camera end.(use a pin in the hole of the ribbon to push it back in later).Unclip it from the housing nearest the top.note alignment of contacts on the pad.I had to bend my contacts very slightly towards the outside on one and in on the other and its works a1 again.The rubber cover for usb plug is easiest to install on the camera body first then put that end back in the housing first.make sure it is properly seated before putting the screws back in.Best of Luck and Happy New Years!
Mar 23, 2009 | Canon PowerShot A560 Digital Camera
Camera freezes when changed from Auto > Scene
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain
Apr 15, 2008 | Nikon Coolpix S3 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
How to increase brightness in Canon Powersot A620 ?
Are you asking about brightness as viewed on the LCD, or are you asking about increasing brightness on the actual image taken? If it's the image, there are two special modes that you can select on your mode dial. They are "Night Scene", "Night Snaphot", and "Indoor". A description of both, along with your camera's other special settings, may be found here:
"Night Scene" can be selected directly from the dial. It's the one showing a person standing under a star. Note that Night Scene should be used with a tripod to reduce the potential for blurriness.
"Night Snapshot" works almost as well, but does not require a tripod. It can be accessed by selecting SCN on the dial, and then pressing right or left with the selection buttons until it shows in the menu. The camera will remember this setting the next time you select SCN. I usually keep my camera always set to this setting so that I merely have to select SCN to use it.
"Indoor" works very well in those large rooms that may produce dark backgrounds when taking photos. It also does not require a tripod. It's accessed the same way as "Night Snapshot" (Select SCN, then right/left until selected). This is another good setting that I like to keep sometimes set in SCN.
Try all three settings, (and don't forget all the others too). Think you'll be impressed.
Feb 23, 2008 | Canon PowerShot A620 Digital Camera
MVC-CD300 for Dummies?
for average still shots, do I need to constantly monitor & adjust scene selection (twilight, landscape, portrait)? No, just leave it on the little teal colored camera. If you want to use the scene selections then it must be on SCN. I unfortunately spent a lot of time when I first got this camera switching between scenes without putting it on SCN - so it didn't really change scenes! Also, when switching modes, must I turn camera off before rotating mode dial? No
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
Canon PowerShot A560 Digital Camera Logo
671 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
