Question about HP OfficeJet J4580 All-In-One Laser Printer
How do i shut off the fax log - HP OfficeJet J4580 All-In-One Laser Printer
  • 23 Answers
In order to clear the Fax logs I request you to perform the below stps.
Click on setup on the All in one printer,
and then click on Tools and select the clear fax logs and press OK.
Now, check the Functionality of the All in one printer.
Posted on Sep 30, 2010
Clearing the fax log on HP J6400 all-in-one fax machine
Once you print out the fax log it should clear the memory. Here are the instructions for printing the log.
To print the fax log from the device control panel
1. On the device control panel, press Setup.
2. Press the arrow key to move down to Print Report, and then press OK.
3. Press the arrow key to move down to Fax Log, and then press OK.
4. Press OK again to print the log
Dec 28, 2012 | HP Office Equipment & Supplies
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
Where is the fax log? I can't find the fax log in
I think you find the fax log,in the menu of the printer,fax settings.
Mar 16, 2011 | Canon Office Equipment & Supplies
8500 hp printer -- cant get red of message -fax log full
clear the fax log...
go to setup menu basic fax setup... scroll to fax log... clear fax log....
in some printer you can find the fax log in the fax settings or advance fax setup..
Feb 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Every time I send a fax, I get a Fax Log. Want to disconnect the fax log.
Hello. Go into the menu and disable the log or set it to print off a log after every, say, 20 faxes. J.
Aug 24, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP 7280 can't find the fax log
On the printer itself hit the setup button (the one with the little wrench)
Then go to print reports and press ok
Then to fax log and press ok.
Jan 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
Can't fax because fax log is full all the time
You need to clear the fax log. Press the control panel's button (right or left) until you see 'fax log' on the display, then press OK or Enter (depending on the printer). Press the control panel's button again until you see 'clear fax log' or 'delete fax log' on the display, then press OK or Enter. You should get a confirmation message on the panel display. You can turn the printer off and then after a few seconds turn it back on. The fax log memory should be empty now.
Nov 27, 2009 | Televison & Video
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Status Code 19
Look in you menus. Your log print out is probably set to on and set to print out way to frequently. You can turn that feature off.
You can go to Xerox.com, click on Support and drivers. In the search box type in 116 then go to support and then type in Log, There should be an answer there as to how to shut off log printing. You cold also type in code 19 when you get to the support page.
May 05, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Restoring sent and received faxes to fax logs
That's not the way to backup your logs. You copied only the fax images, and not the logs to go with them. This is a common error that is made quite often. Unless you have the original log structure, your data (logs) that link to the actual fax images (fxds, fxrs, etc.) are lost.
Troubleshooting WinFax suggestion:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Jan 02, 2009 | Symantec WinFax Pro for PC
HP OfficeJet J4580 All-In-One Laser Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
