Question about Kenmore Refrigerators
I have a kenmore ice maker with a white, a brown,a green and a orange wire that were in a 4 pin round plug. i cut them out to put in a 4 pin flat plug in a whirlpool fridge model BT14UKXNA00 that has a green , a brown , a black and a white wire. Does the green connect to the green, the white connect to the white and the brown connect to the brown leaving the black and orange to connect? I cant afford a new ice maker or a kit with the round to flat plug adapter so any help would be great. THANK YOU Stephen
  • stephen bruno
    stephen bruno Oct 03, 2010
    Kenmore ice maker and the white plastic end cap has a wiring diagram inside it showing the orange wire going to the hold switch and then to the feeler arm switch, the brown wire going to a relay or junction or splitter where it goes in two directions one to the motor and one to a mold heater , the white wire going to the water switch and the green going to a ground i believe it is.
    Kenmore ice maker with a white, a brown,a green and a orange wire that were in a 4 pin round plug. i cut them out to put in a 4 pin flat plug in a whirlpool fridge model BT14UKXNA00 that has a green , a brown , a black and a white wire. Does the green connect to the green, the white connect to the white and the brown connect to the brown leaving the black and orange to connect? I cant afford a new ice maker or a kit with the round to flat plug adapter so any help would be great. THANK YOU Stephen
SOURCE: RADIO INSTALLING
with the bose sound system you have to bypass the audio system through the factory amp. the factory is located behind the right side of the glove box.
Posted on Sep 29, 2008
ourhowse
  • 2007 Answers
SOURCE: I have a pre fab wiring harness on my trailer with
I assume you only want lights, brake lights and signals. Your best bet is to plug a wire onto your truck... the flat plug, and turn , first the left signal, on. Use a test light to see which part of the plug in is flashing. Once you have established that, just keep plugging the other end of the wire into the trailer plug, until you get the left turn signal flashing on the trailer. Then repeat the process for lights etc.
You can also take the plug-in apart on the trailer. Inside the plug in it will have l/t, r/t, s, etc. (left turn, right turn, stop, etc.) There will be a very small arrow pointing to the terminal connection that is for each.
Posted on Nov 03, 2009
Testimonial: "Thanks, that should be an easy and sure way."
  • 22 Answers
SOURCE: wiring ice maker old ice maker has a 4 square plug
wiring is different and you will probably short out something. this is 120 volts and you could get a shock! leave this to a professional. other wise the only thing i would tell you is compare the electrical schematics from both ice makers to varify power and control wiring.
Posted on Nov 24, 2009
  • 905 Answers
SOURCE: jayco camper has 6-plug connector------car has
It would be easiest, and best, if you were to upgrade the cars' trailer connector. The 4 way just supplies brake, parking, turnsignal, and a ground. The colors are the same on the 6 way, but 2 lines are added, usually for a electric brake controller and aux. circuit. Be careful about using the battery line (Red) on the 6 way connector unless you are also upgrading the white wire to a heavier gauge (at least the same size as red).
Green - Stop and Right Turn Signal (4/5/6/7 way)
Yellow - Stop and Left Turn Signal (4/5/6/7 way)
Brown - Running Lights (tail, side, tag) (4/5/6/7 way)
White - Ground / Negative (4/5/6/7)
Blue - Electric Brakes (5/6/7 way)
Red - Aux. charge line for emergency break away, battery charger, etc. (7 way)
Purple - Aux. backup lights / other purpose (7 way)
Posted on Aug 18, 2010
rockmeister
  • 2047 Answers
SOURCE: i have a fridge equipped
Usually the fact that the wires have the same color does not mean that they are meant to go together. But in your situation since the other colors match then they are menat to go together. Although according to color coding the black is meant to be neutral while orange also stands for neutral.so both wires could go together. But in rare cases the wires coding could have been mixed up so best get an expert to examine it and test the cables to determine which is which to avoid unforeseen damage.
Hope this solution has been helpful?
Posted on Mar 19, 2011
I have a Q-SEE security camera, that received water damage from a rain storm. The ethernet connector had to be removed and I am interested in hardwiring the camera to my CAT5e cable. The QCN8004B camera...
I had the same problem and had to rewire the ethernet jack on my Q-See camera QCN7001B.
The wiring I found was different than on the Q-See website.
Pin 1 is brown
Pin 2 is purple
Pin 3 is orange
Pin 4 is yellow
Pin 5 is blank
Pin 6 is blue
Pin 7 is blank
Pin 8 is grey
Jeff
Apr 06, 2014 | Security Labs Home Security
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
I have a Kenmore refri/freezer model 106.7687460. with the icemaker removed the unit will not operate. I need a wiring diagram or which wires needs to be connected at icemaker connection.
Good day,
the defrosting control is a part of the ice maker. If you don't care about appearances, you can wire around it.
First, you have to buy a 8 hour 20 minute Whirlpool defrost timer.
Any sharp appliance parts house counter guy will know what you need. It comes with one of the clock wires un-attached.
As well, you will need 4 insulated 1/4" female spade connectors.
Buy spares to be safe.
Cut the cord from the old ice maker at the ice maker.
There will be 5 main wires and a green ground wire.
Strip about 1" of the green wire's insulation.
There will be 5 wires left. red-orange-black-pink-brown.
Tape the brown wire back it will not be used.
strip back approx. 1/4" of the remaining wires. crimp a spade connector to each of the 4 remaining wires.
The terminals will look like this.... | | | | on the timer.
Notice the space between the first terminal and the second, compared to the rest.
We will call the terminals on the timer from left to right, 1,2,3,and 4 even though the timer will say differently.
Connect the loose wire on the timer to terminal 4.
Plug the red to #1, Orange to #2, black to #3, and pink to #4.
Plug into machine, and run to test. If O.K. then........
Using high quality electrical tape, tape everything exposed well.
Mount the timer to the wall using one of the left over holes from removing ice maker.
Drill a tiny hole, close to that area, and using a good self tapping screw, attach the green grounding wire. Detail your work as necessary.
It's ugly, but it works. Actually, I install the timer inside the case after gutting the works. If you want to try that, DO NOT cut the cord, as explained at the beginning.
Note: Some supply houses may still sell the adapter, already made up. You can check. In either case, you must have a timer in the circuit for defrosting.
Dec 03, 2009 | Kenmore Refrigerators
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Cat 5 Issue you replied to
The color is not so important as the cable follow the same standard on both ends.
It has been my misfortune to find non-standard wiring in a facility, so long as they keep the relationship of the pins the same it will work, if the installer did not then you cannot trust any of the work and MUST either redo it all or have it all tested and certified by a cometent network cable installer.
568-B Wiring
Blue/White 4
Orange White 2
Green/White 6
Brown/White 8
568-A Wiring
Blue/White 4
Green/White 2
Orange/White 6
Brown/White 8
Apr 21, 2008 | Computers & Internet
Ice Maker installation
the im will only fill when the fingers are at the 12 o;clock position TO cycle your IM ...remove the cover and insert a jumper wire in the T and H holes once you hear a faint click or after 15 sec remove the jumper the im will continue to rotate when it hits (the fingers) the 12 o'clock spot the fill valve is energize for 7 sec then the finger come to rest and stop at the 2 o'clcok position..Let me know if you need more info
Feb 19, 2008 | Refrigerators
Refrigerators Logo
246 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
