D-Link AirPlus Xtreme G DI-624 Wireless Router Logo
Posted on Sep 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I keep getting a connection failed signal when i try to connect my new brother 9320 printer, my wep password is correct but won,t connect
Anonymous
Level 2:
Sergeant:
  • Expert 270 Answers
  • Posted on Sep 29, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
270
Questions
0
Helped
68573
Points
864
If you have a security suite, you may need to permit access thru the firewall to the IP addy assigned to the printer.
Also as a diagnostic measure, I would connect a USB cable to the printer to make sure the drivers are correct on the printer.
After those steps were accomplished, I would check my router's log to see if the printer registered with it.
good luck and don't forget to vote!!!
How do I When Brother Printer not connecting to WiFi?
When the Brother Printer not connecting to WiFi device or network, many reasons behind that below mention
Incorrect using the Wireless network
Using the Weak Wi-Fi signal
Brother printer away from Wi-Fi router
Incorrect using the Wi-Fi network setting
Firmware and Printer driver out of updated or not updated with the latest version
Printer driver corrupted condition
SSID or network incorrect using
If you will solve the above reason then your brother printer is easy to connect with a Wi-Fi network.
Now Get resolved the Brother Printer Won't connect to the Wi-Fi network?
Get below the troubleshooting steps to solve the Brother printer not connecting to the Wi-Fi issues.
Step1: Using the correct the Wireless network
Step2: Wi-Fi network must be strong
Step3: Printer placed near the Wi-Fi router or network
Step4: Printer WPS setting must be correct
Step5: Update the Firmware and driver problem
Step6: Use the latest version printer driver
Step7: Correct using the SSID network setting
Next also Read: How to fix the Brother Printer In Error State?
Brother MFC 9840 CDW. How can I connect to wi-Fi?
Full instructions from the Brother website
Set up your Brother machine on a wireless network.
> Click here to see how to find the wireless security information for Windows.
For Macintosh users
> Click here to see how to find the wireless security information for Macintosh.
After checking the network information of your wireless router or access point, go to step 2 to set up your machine on a wireless network.
If your wireless router or access point uses WEP encryption with multiple WEP keys, write down and use only the first WEP key.
2. Set up a Brother machine on a wireless network
To set up your Brother machine on a wireless network:
  1. Connect the power cord to your Brother machine and then connect it to an AC power outlet (electrical socket).
    Turn your Brother machine on.
  2. > Click here to see how to reset the network settings.
  3. Press the Up or Down arrow key to select the following:
    1. Select Network or LAN. Press OK.
    2. Select WLAN. Press OK.
    3. Select Setup Wizard. Press OK.
    4. When WLAN Enable? or Network I/F switched to Wireless appears, enable the wireless network.
      This will start the wireless setup wizard.
  4. The machine will search for your network and display a list of available Network Names (SSIDs).
    When a list of SSIDs appears, press the Up or Down arrow keys to select the SSID you wrote down earlier.
  5. Press OK.
  6. Press the Up or Down arrow key to select one of the options below: If your network is configured for Authentication and Encryption you must match the settings used for your network.
    Available authentication and encryption methods depend on your model.
    • No Authentication or Encryption:
      Select Open System, press OK then select None for Encryption Type? and press OK.
      To apply the settings, select Yes.
    • No Authentication with WEP Encryption:
      Select Open System, press OK then use the Up or Down arrow key to select WEP for the Encryption Type? and press OK.
      Select the appropriate key number and press OK.
      Enter the WEP key (Network Key), then press OK to apply your settings.
    • Authentication with WEP Encryption:
      Select Shared Key and press OK.
    • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:
      Select WPA/WPA2-PSK, press OK then use the Up or Down arrow key to select TKIP or AES for the Encryption Type? and press OK.
      Enter the WPA/WPA2-PSK password (Network Key), then press OK to apply your settings.
    • Authentication with LEAP:
      Select LEAP, press OK.
      Enter the user name and press OK.
      Enter the password (Network Key), then press OK to apply your settings.
    • Authentication with EAP-FAX/NONE, EAP-FAQT/MS-CHAPv2, EAP-FAXT/GTC (TKIP or AES Encryption):
      Select EAP-FAST/NONE, EAP-FAST/MSCHAP(EAP-FAST/MS-SHAPv2) or EAP-FAST/GTC, press OK then use the Up or Down arrow key to select TKIP or AES for the Encryption Type? and press OK.
  7. The machine tries to connect to the wireless network you have selected.
    • If your Brother machine connected successfully
      The machine's LCD displays Connected.
    • If the connection failed The machine's LCD displays Connection Fail or Connection NG.
      Make sure your access point is on, and verify your Network Settings collected in Step1.
      Temporarily move your machine as close as possible to the access point or router. Try starting from Step 2-2 again.
  8. The machine will automatically acquire the correct TCP/IP address information from your access point/router if DHCP is enabled (DHCP is normally enabled as default for most access point routers).
    Once the Brother machine is joined to the network and has a valid IP address, the wireless setup is complete.
Videos
https://www.google.com/search?q=Brother+MFC+9840+CDW.+How+can+I+connect+to+wi-Fi%3F
Networking Guide
https://download.brother.com/welcome/doc002260/mfc9840_usaukasa_net_a.pdf
I can't get the printer on the wireless network because something is wrong with the wep password, I have a newer apple wireless router but it wont let me get past the password part.
Verify the router is set for wep and that you give it the correct info. numbers 0 through 9 and A through F so putting a password of password will not work.
Try something like 1423DDA244.
Beter Yet:
Set the router for WPA2 mode and then you can have the password of your choise and a more succure connection.
1helpful
4answers
BROTHER MFC-6490CW won't connect to wireless router
Having the same issue with 6490CW and Uverse internet. It connected just fine to my wireless when I had AT&T DSL. Well, just fine is an overstatement, it would constantly go "offline" and need to be re-connected but at least it printed fine when it was. Now, I switched to Uverse and it WILL NOT connect wirelessly. I went the cabled ethernet route and it STILL has tons of issues recognizing the printer and printing, often stopping mid print and spitting out a half printed page or just not printing at all and telling me the printer is turned off. Next step is to try connecting with a straight up USB connection, bypassing the network completely. I feel like that's my only option short of getting a new printer. Brother's software simply does not work with some networks it seems. I guess it has issues with FIOS as well. This does not surprise me and it is also not surprising that Brother has not updated the drivers for my printer since 2009. Pretty ridiculous since things have changed a lot on the technology front in almost 4 years.
1helpful
My printer has stopped communicating with our BT home hub It was OK and the security code is correct it just cannot establish a connection. I tried it with the previous Netgear wi fi and it connects just...
you can also change the BT home hub 2.0(black)encryption type to WEP type. all you need to do is follow the steps to change the type of encryption to WEP.
  • connect a computer using the ethernet cable to the hub(its the black cable with yellow leads).
  • open an internet explorer or anyother browser, in the address bar just type 192.168.1.254.
  • you will be getting the BT home hub manager page with please reset your password, asking for three credentials.
  • in the first bar enter the default admin password or the admin password which is found in the wireless card or at the back of the home hub in the label. in the second and third bars enter the password of your own, something like admin1.
  • you will be getting another page coming with four options at the top (home, services, settings and troubleshooting).
  • click on settings, and below troubleshooting in the blue bar itself , you will see advanced settings. click on it.
  • then click on continue to advanced settings, now below home in the blue bar itself, click on wireless.
  • after you do that, you will see two options called as configuration and security. click on security. there you will see the option to change the wireless encryption to WEP.after changing the type to WEP, type the same password again in the section for password and click on apply to save changes.
  • check whether your printer is connecting to your home hub after that,
I am a person who work for BT in the tech help desk dept. if you have any trouble in doing this please reply to this message
1helpful
Connot connect printer to wireless router
this may be due to the security password that is enabled in the router... its recommended to use WEP password in router to connect wireless devices...if you use any other encryption type like WPA/WPA2 then change it to WEP and connect it....if it is a belkin router then you need to disable the WiFi protected setup too.......
1helpful
2answers
Cant get my printer s305 to connect to wireless,wont accept wep key ,, any way round it, please help
Good day! There are things you need to check to successfully connect the printer for wireless connection.
1. Make sure the wifi light on the printer is solid orange before continuing. If not, go to Setup > Network Setup > Reset Network Adapter to Defaults. Wifi light should turn off, then wait for it to turn solid orange.
2. WEP key can be ASCII or HEX(hexadecimal) depending on what was assigned to it. You may be using an incorrect WEP key. Just to make sure, access your router setup page and double-check the WEP key assigned to it. If you don't know how to access the router setup page, you can always ask assistance from either your internet service company or the router's manufacturer.
Once you get the correct WEP key and wifi light solid orange on the printer, try connecting the printer again for wireless connection. Good luck!
My wireless network gets dropped
HI! that is correct.. your device wont connect bcoz you change the wep, ssid name etc on the router.. if the security settings is change from the router and your wireless devices have the old settings it wont work and it will not connect.. you need to enter the new wep, ssid name etc to the wireless devices in order to connect to the wireless network..
Cant connect to the internet, and not sure what my wep key is
ok playstations arn't the best for connecting to the internet but they can connect none the less. first get your router closer to your ps3 to make the connection strength better or purchase a signal booster. get you connection evaluated and see if your ps3 is working properley by disconecting it from the mains for about an hour and then reconecting it to the mains. it might connect then but try a signal booster, it might help but it's probably your internet. - good luck
3helpful
2answers
Trying to connect Wireless printer
Will it connect without security. Try it out and let me know what you get.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
