Question about Food Mixers
Moulinex Regal Pasta and Dough Maker
I have a Moulinex Regal Pasta and Dough Maker, that I got from a friend and I need part for this machine, Do you know where I can get the parts for this kind of machine? it is model V717
  • 4 more comments
  • Joan Zucker Aug 07, 2008
    Me too. And same model. Please let me know what you find out.
  • drbunce Sep 09, 2008
    I have the same model - V717 - and I'm missing the mixer nut and two of the pasta discs. Where do I find these parts?
  • THERESA772 Nov 10, 2008
  • Anonymous Nov 26, 2008
    Found a machine at Goodwill, it's missing the extrusion screw. Hoping to find this part.
  • msmichelle20 Dec 03, 2008
    I am also missing the disc holder with knife.
    Please let me know if you have one to part out.
    If not then I am open to parting out mine, as I have all other parts except for the disc holder.
  • enza698 Mar 02, 2009
    I'm missing the disks & I'm unable to replace them I need to know wher to purchase them
I have the Maulinx Regal Pasta Maker from my mom, I need to find the manual on how to use it. Anyone have any suggestion?
Posted on Aug 29, 2009
I can't get the mixer parts in the hole to fit in. The model no is k5ss.i want to use my roller to make pasta dough?
Sometimes the square shaft of the attachment does not quite line up with the square hole in in the drive of the mixer. Take a look in the mixer's attachment port and turn the attachment's shaft so that the two line up.
Dec 17, 2017 | Food Mixers
Need instrucion manual for moulinex electric meat grinder & salad maker
You don't mention what model number, but you might try this page. It has several meat grinder instructions booklets you can download.
Jul 22, 2014 | Food Mixers
Hi, We have a 3phase Hobart D300 Mixer onboard and the cooks are complaining that there is not enough grunt. I have checked the 3 speeds and they are working finee however when dough is being mixed it...
Hello Veelec,
As the machine is mixing dough it seems that it is getting sluggish. This is caused by the machine being over loaded. Although it is a 30 qt mixer that is for liquid filled capacity. I do not know what kind of dough you are mixing so I will give you a light to medium dough and then the heavy dough capacity. Also on this machine all dough should be mixed in speed 1 or low to keep from damaging the machine.
You will need to know the Absorption Rate (AR) of you dough, to find this you take the weight of the water divide the weight of the water and multiply by 100.
AR = Water Weight / Flour Weight x 100%
The higher the percent the higher the capacity the lower the percent the lower the capacity. Also the temperature of the water will have to be considered as the colder the water the harder the dough it is to mix the dough the batch should be reduced by 15% to 20% for water temperature between 65-75 degrees.
For a Light to Medium dough with a 60% AR the unit capacity is 45 pounds in first speed.
For a Heavy dough at 55% the units capacity is 30 pounds in first speed.
The above capacities are for bread doughs, if you are doing pizza dough, dough nut dough or wheat dough please post back to this thread and I will help you to find the capacities.
I hope that I have helped you with your problem and would like to thank you for using FixYa to find a solution to your problem.
Mar 02, 2011 | Hobart D300 Stand Mixer
How do you use the KitchenAid SNFGA Pasta Maker Attachment
If it's gumming up, the dough is too wet and needs to be dried out more by adding flour. The right consistency dough is such that if you tear off a small piece and then tear it in half and squeeze it back together with your fingers it should stick back together but not stay stuck to your fingers. If it stays stuck to your fingers it's too wet and needs more flour. If it is crumbly, it's too dry and needs more water.
Apr 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Kitchenaid Household stand mixer. Model no.
it is hard to tell you exactly what it could be, but a common problem is after a while the transmission gasket does deteriorate and will begin to leak oil.the gasket is part number4162324. the rattling noise inside your unit is most likely cause by a chipped gear inside, this can happen when the unit is put under heavy loads, such as dough. this problem could get worse as there may be fragments inside that will damage it more.hope this helps
Oct 04, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Need instruction manual for Waring Primo Pasta maker
Here is one:
Could someone tell me how much flour the flour cup holds, compared to a regular measuring cup?
Apr 02, 2009 | Food Mixers
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
Oil seal gone - is there a catering equipment facility near you? If not do you know any one who can take it down= if you can get the parts[Google the maker for parts] Perhaps you have an Auto engineer nearby
May 14, 2007 | Globe SP30 Stand Mixer
Food Mixers Logo
575 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
