Question about Intel Motherboard
What converter should i buy to attached my additional hard disk please show me
Additional hard disk to motherboard connection
    Scholar:
  • 187 Answers
Am I right in thinking you want two drives on a single laptop IDE? (assuming due to the laptop picture displayed with your post). If so, I'd strongly recommend going with a USB external drive instead.
Posted on May 25, 2008
Seagate hard disk is not showing
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps you
Sep 14, 2011 | Maxtor (6L250S0-20PK) (6L250S020PK) 250 GB...
While the computer is switched on it shows the command insert any harddrive in a black colored screen sometimes and sometimes if it starts it shows a caution "Windows detected a hard disk...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 22, 2011 | Computers & Internet
Can Vantec CB-IS100 IDE to SATA converter works to convert Motherboard ide port to sata or it made only for hard drives,cd-roms and DVD rom ?
It attaches directly to the drive, whether it be IDE hard disk or CD/DVD, and is used in boxes that already have sata connectors on the MB. Connector attaches to drive, cable from connector attached to drive to sata connection on MB.
Note: Sometimes these may not work (for a variety of different reasons).
Here is a link to one seller of the converter, read through the reviews. While it works well for most, sometimes there are issues.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004
Dec 26, 2010 | Vantec CB-IS100 IDE to SATA converter IDE...
I attached a sata hard disk in addition to the existing ide hard disk drive in my pt800ce-a motherboard. But the system cannot detect the said sata hard disk. what should i do?
If your existing system is IDE motherboard your new SATA drive will not work as it will have compatibility issue, also the MB will not support it.
The same goes for RAMs, 2 uncompatible RAMs will make the PC slow down or keep shutting down....
I guess you have used an adaptor to connect a SATA disk/cable to the IDE MB, check that, it may be the issue also.
Regards
pls leave a feedback and reply
Nov 11, 2010 | EliteGroup PT800CE-A Motherboard
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
Disconnected the power supply for mercury motherboard but now it powers but the hard disk doesnt power nor does the screen show anything its just on what might be the problem???? please help
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 17, 2010 | Mercury P4VM800M7 Motherboard
Intel 865GSA
Looking at the vendors I buy parts from, all the cards I saw offer both SATA and IDE ports. Here's one as an example. You definitely want SATA capability as most newer drives are only being offered as SATA, so you'll have a wider selection to choose from.
Another possibility: start fresh with a new system board. If the onboard IDE controller isn't working properly, this may be a warning sign that other problems follow. You might be better off spending your money on a new mobo that already supports IDE and SATA.
Hope this helps you make up your mind. Thanks for using Fixya!
Feb 20, 2010 | Intel 865G Motherboard
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: support@compudesk.in
Oct 12, 2009 | Intel D865GVHZ Motherboard
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
Intel Motherboard Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
