Question about Trilogy ALARM LOCK PL3000 Series T3 Prox Cards Only Keyless Lock
Replaced batteries, upon reconnect I get three beeps and ten seconds later, continuous beeping unless i unplug the battery...keypad unresponsive during this time...
  • 963 Answers
Http://www.alarmlock.com/
From here you will find technical documents and a link to customer service for further assistance.
Posted on Nov 09, 2011
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
Began to beep in intervals. Changed batteries and it worked a couple of times then beeped twice then touchpad will not work, Five minutes later it beeped steadily for 10 seconds than stopped. Will not...
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Sep 22, 2011 | Weiser Lock Powerbolt 1000 Lock
The unit was beeping intermittantly then a continuous beep. I replaced the batteries. No change in beeping
Navigate to the complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Then go to: US & International/FAQ Categories/Keyless Entry/Powerbolt 1000/Search Results/ How do I troubleshoot my Powerbolt 1000?
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Good luck--and please provide feedback if this helps.
Aug 29, 2011 | Weiser Lock Powerbolt 1000 Lock
Some button on the keypad beep while others don't. After disconnecting the powerband and reconnecting, it beeps once when batteries were reinserted. After trying to set new codes, some buttons still...
Powerbolt is Beeping?
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
Jul 24, 2011 | Weiser Lock Powerbolt 1000 Lock
The lock started beeping every couple of minutes so we changed the batteries and the problem continued. The lock was working ok just wouldn't stop beeping. It is probably close to 10 years old and I...
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.Since you stated that your lock is ten years old, this is likely the case.
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. And to confirm that you indeed are concerned with the correct model of lock! Secondly, they will be able to get the correct part on order for you.
This link should take you to the complete installation and programming instructions:(cut & paste into browser)
https://s3.amazonaws.com/Kwikset/Powerbolt%201000%20-%20Installation%20Instructions.pdf
Jul 03, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Hi. Have had the lock on for at least 5 yars and has worked fine but now suddenly a problem. Locksmiths say its electrical so not their problem and vice versa so very frustrating.. Heres the...
Jun 25, 2011 | Weiser Lock GED1460X GED1460X15A Antique...
My lock works for awhile then stops. The beeps sound all the time, then stops locking & unlocking using the keypad. Then a day or two it works again.
Here's a link to the Powerbolt 1000 frequently Asked Questions page:
You will find this answer on that page:
Feb 10, 2011 | Weiser Lock Powerbolt 1000 Lock
My unit started beeping continually, I changed batteries, but
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Aug 29, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Powerbolt 1000 started beeping and quit functioning
US: 800-677-LOCK
-=dån=-
Jun 14, 2009 | Weiser Lock Powerbolt 1000 Lock
Won't accept new code
US: 800-677-LOCK
-=dån=-
May 27, 2009 | Weiser Lock Powerbolt 1000 Lock
Trilogy ALARM LOCK PL3000 Series  T3 Prox Cards Only Keyless Lock Logo
167 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
