Question about Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens
My lens' focusing is malfunctioning. When I use Auto Focus, it's fine. But when I switch to manual focus, when I turn the focus, it's hard to turn and it makes a crackling sound. as if something is stopping me from turning it. when I use other lenses on my d3000, everything works well. Only my 55-200mm lens has a problem. I'm sure I switched it to manual focus, I'm not stupid to turn it while it's on auto focus. Your help will be greatly appreciated. Thanks.
  • Nikon Master
  • 5,322 Answers
Is there also an AF / MF switch on the camera body ?
Posted on Jun 15, 2017
3 Suggested Answers
fblock
  • 289 Answers
SOURCE: Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Posted on Apr 24, 2009
  • 4090 Answers
SOURCE: lens unable to auto focus
try cleaning the lens.
Also set the focus range in the camera to average both vertically and horizontally. That is when you press the shutter button thos red squares in the look through a;; ;light up rather than just the centre square.
I suspect it is getting feedback from something on the lens that it reads and tries to focus on that is closer than the object you want to photograph. Make sure there is no mold growth inside lens as that will do it too
Please rate my help++++Thanks for using FIXYA
Posted on May 17, 2010
Auto focus
Have you checked the lens to see if auto focus is turned on? Sometimes the switch can get accidentally turned to the manual focus position.
Aug 24, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Mar 24, 2012 | Canon Digital Rebel EOS 450D EOS Rebel XSi...
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
My 18-55mm lens won't auto focus...it works in manual my 55-200mm works fine on my D3000
-You must use a lens with internal auto-focus motor such as AF-S Nikkor, or 3rd party with built-in motor
-Is the switch`s been moved to A/M??
-The battery must have enough power to run the auto-focus motor inside the lens
Dec 25, 2010 | Nikon D3000 Digital Camera
My Nikon D200 digital camera will not focus when I depress the shutter butteon half way and will not take picture when shutter is completely depressed. this all started after I downloaded my pictures to my...
Hard to pinpoint the exact problem...
What lens do you have attached? Does it have a switch for M/A and M (auto focus/manual focus)? If it does ensure the switch is in the M/A or Auto Focus position.
On the left side of the camera on the face there are 3 positions, C, S, and M. Ensure it is not on "M" for manual.
Do you have your camera setup to only allow the shutter to operate when it is in focus?
Dec 15, 2009 | Nikon D200 Digital Camera with 18-200mm...
Auto focus is not working properly and will not
You want to charge people for a membership to get answers from your site
but you want me to "tell you how I did it" for free. Hmmmmmm?
Sep 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Will not auto focus with a smaller lens.
I had the same issue with my Nikon d60...my 18-55mm did auto focus but my 55-200mm only manual focused, i thought it might have been my camera as i heard that not all lenses are compatible with my d60 but it turned out to be the focussing motor or something that was damaged, it was making a very funny noise when it tried to auto focus with it,like a screeching sound..if this is the case you should get it repaired and looked at, also check on the lens if it says it is a AF lens,if so make sure th switch on the side of the lens is switched on AF not MF. hope it helps
cheers
May 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
  • D80 was "on"
  • M/A
  • VR = Off
Hope this helps!
Apr 09, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Canon 3000N Auto focus fault
No extra batteries.
Usually this is a lens fault as the focusing gear is all in the lens. Clicking sounds as if a rear pinion has cracked. It's not uncomon in the 'prosumer' level lenses where plastic gears are used a lot.
It's just possible the fault is which the auto-manual switch. This usually has a mechanical clutch coupled to it which physically disconnects the gearbox from the focusing ring, as well as operating a switch to tell the camera to turn off the AF system.
Dec 21, 2008 | Nikon F65 35mm SLR Camera
Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Sep 28, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
