Question about Cuisinart SPB-7 SmartPower Work Top Blender
Replacing Black Plastic Coupling
How do you remove the black plastic coupling that is attached to the motor base, so I can replace it with a new one?
  • 2 more comments
  • Kelan Jun 11, 2008
    How can I remove the black pastic? Where can I purchase this black plastic piece. If I am not able to replace my self on which repair shop can I go to. Calgary Alberta. Johanne
  • r_wally Nov 30, 2008
    Did you ever find a place to buy the plastic coupling. My wife broke our also and i need to find a replacement.
    RW
  • jmc88011 Dec 08, 2008
    Black coupling from motor broke and Cuisinart does not offer it as a part for sale on thier web site
  • William Chatfield
    William Chatfield Feb 15, 2009
    The better solution (rather than jambing wrenches into the motor vanes is to take the entire motor, printed circuit board out of the plastic case. The other end of the motor shft has a slot for a screwdriver... so yes - lock the brass coupling in a vice - then use a good size screwdriver to unscrew - reverse thread of course.
The part number is Cuisinart SPB7-20TXN and can be found on amazon.com. If this part is broken you will need to remove the brass coupling. Make sure you turn it clockwise not counter-clockwise as someone mentioned.
Posted on Dec 05, 2008
    Problem Solver:
  • 16 Answers
On mine, I clamped down the end of the motor shaft to a bench vise real hard and then I used a 7/8-inch open-end wrench to wedge into the clutch prongs which made it much easier to apply torque. Remember that its screw threads are reversed from normal screws so that it does not unscrew during operation. You have to turn it counter-clockwise to unthread it, opposite of a regular screw.
Hope that helps!
-Vince
Posted on Oct 01, 2008
Removing coupler
You undo it by shocking it in the same direction it normally turns with the motor. Drill a hole in that top flange, engage a punch or screwdriver into the hole and hit it in the correct direction with a largish hammer. If you do it right it takes 1 to 4 whacks.
Jan 11, 2014 | KitchenAid 3-Speed Blender Onyx Black...
How to separate coupler
Assemble it with motor secure and base & feet on. Drill 3 or 4mm hole in edge of coupling Put screwdriver into hole on a large angle and whack the handle to undo the coupling. You are whacking it to turn in the same direction it turns when the motor is running.
Nov 20, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Braun type 4191 blender shaft coupling faulty
I had the same problem, the authorized service told they cant fix it, so i tried it. First, I show you the solution:
You see the black one you attach the heads to. The axis come from the motor with the little teeths: the black plastic wore away that's why the motor works but the end doesnt rotate.
You can simply pull the black one out with a pliers with medium force and if you get a new one(thats the hardest, they wont sell you) that will works.
For the mankind, ive totally flatten out my type 4191, so i show you some pics, how to solve yours:
if you had problem with the motor, simply cut it half. You wont harm anything, the motor is in a metal cylinder.
If you have some promblem with the electronic part, its in the end of the blender. You can open it at the top, but you cant reach anything form there, nor here, sad story.
finally some photos from the bottom:
Enjoy it!
Jan 06, 2011 | Braun MR 550 M MultiQuick Handheld Blender
Part "i" , the plastic(nylon) tooth part on my Braun PowerMax Blender, type 4184, broke and I need to find a replacement part. The Braun Service website was useless. Can you help? ...
www.smallappliance.com. you can order a new blender blade which has the white nylon teeth or you can order the coupling which is the black teeth that the jar sits on. NOTE: the black one is easy to replace, but getting the screws out of the base is the hard part.
Jul 02, 2010 | Braun MX 2050 PowerMax Work Top Blender
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
You can order this part Black and Decker Blender Base Collar Ring BL5000-11
I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
May 26, 2009 | Black & Decker BL1900R Blender
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Broken blender coupling
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Dec 15, 2008 | Black & Decker BL600 ProBlend Work Top...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Cuisinart SPB-7 SmartPower Work Top Blender Logo
728 people viewed this question
Top Cuisinart Blenders Experts
Mike Cairns
Mike Cairns
eyecam
sonic boom...
sonic boom...
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
