Question about HP DeskJet 1220c InkJet Printer
Wont turn on after paper jam - HP DeskJet 1220c InkJet Printer
    Scholar:
  • 107 Answers
In the back of printer there is the cover that has a turn style locking mechanism, it must be fully into locked area, because it trips a sensor. if this locking system sticks, it can be lubed, but the assembly will have to pulled apart to do this,
Posted on Sep 29, 2010
Printer has new ink & wont print also has paper jam
The paper jam is the problem.
Clear the paper jam, recycle (Turn off, then turn on the printer) , and the other problems will go away by themselves.
Oct 25, 2015 | Office Equipment & Supplies
Wont print....it says paper jam....but not paper is jammed. what to do?
make sure you check the manual and open all inspection areas to remove any scrap paper, its normally the cause
Jul 21, 2014 | Canon PIXMA iP1600 Printer
Rx585 paper jam
Turn off the printer and turn it back on. It just needs restarting.
David
Jun 18, 2013 | Epson RX585/RX595/RX610
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
It never works cuz the screen says error 5700 and wont do anything
Error 5700 is usually a paper "feed" jam.Check the automatic paper feed area to see if any paper is jammed
May 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Dispalays Reads paper jam and wont disappear
Unplug the power cord then put it back up. This restarts the printer again in case the on/off button does not work to turn the printer off. Then check if there's a paper jam. To do this open the scanner lid and also the glass lid, just the way you access the inks when replacing them. Check to see if there's any paper stuck underneath the inks by the printer rollers along the paper path.
Apr 06, 2009 | Lexmark X4650 InkJet Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Paper jam
You should check the inside of the printer for litle peaces of paper and turn off e turn on the printer.
Nov 06, 2008 | HP DeskJet F380 All-In-One Printer
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
HP DeskJet 1220c InkJet Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
