Question about HP Pavilion dv6000z Notebook
My pc wont boot. displays codes that refer to having a low or faulty battery!!
  • 3 Answers
Replace the battery
Posted on Sep 30, 2010
Screen flashes colors
The issue (flashes" colored screens) you're facing could be related to drivers and could be resolved by updating the display drivers. Without the correct driver, the hardware or device that you want to use won't work properly.
Also refer to:
http://windows.microsoft.com/en-us/windows7/update-a-driver-for-hardware-that-isnt-working-properly
Let's try to boot the computer in low resolution mode and check the issue status.
Low resolution starts Windows using your current video driver and using low resolution and refresh rate settings. You can use this mode to reset your display settings.
Refer the section:
Enable low-resolution video (640×480)
Apr 24, 2014 | Microsoft Inspiron Notebook
Beeping & no display
beeping at boot means different things. google beep codes if you have another pc?. could be ram failure, processor, mobo failure , etc. Or..it could be a flat battery-which can stuff up the bios and wont boot. So check the mobo batt isnt flat first and reset the mobo bios- jumper pin. Hope that helps.
Oct 14, 2013 | IBM IntelliStation M Pro 6218 PC Desktop
My dodge caravan 4 cylinder engine has trouble codes 0016,0113,0700,0562
code p0016refers to the crankshaft /cam shaft position sensor bank 1 sensor A-- correlation===causes---Wiring CKP sensor--CMP sensor--mechanical fault Check timing belt is not broken
code po113 refers to intake air temp (IAT) sensor--circuit malfunction===causes ---wiring open circuit/short to positive--wiring short to ground---ground wire defective IAT sensor---ECM
code mp0700 refers to transmission control system/MIL-malfunction===causes--wiring ---TCM
code po562 refers to system voltage low==causes---wiring poor connections---battery---alternator or it also refers to ECM power relay control--circuit open===causes ---wiring--ECM ---relay. For this one check the battery terminals and posts are shiny clean and tight . Have a load test done on the battery to check for faulty cell. check condition of alternator drive belt and check alternator out put.
Sep 27, 2013 | 2003 Dodge Caravan
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Toshiba Satellite M35-S320 i push the power button and it acts like it wants to boot up i can hear the hd working but video wont come on its a new display?
Please connect an external monitor to the port and if there is display then the monitor is faulty. If not the PC has errors and so you can check the back up battery for CMOS and also the memory on the motherboard.
Ideally it is best to swap a memory card as the battery voltage can be measured to confirm, Other wise the motherboard has errors.
Aug 11, 2011 | Computers & Internet
Power light comes on for about ten sec then it shuts off. wont boot up
Check the bios battery it can be weak and so may not boot the PC. Also remove the main battery and reinsert. check the adapter and see the voltage at the terminals.
If low battery can be weak and might need a replacement.
If not the mother board can be faulty
Apr 16, 2011 | Dell Latitude D600 Notebook
When i boot up, my Compaq CQ20 displays the message that the battery has low storage capacity. Battery time is now down to 15 to 20 minutes at full charge.
If you laptop is more than two years old then it is possible that the battery is faulty as many of the compaq laptops have poor back up battery orr quality retained.
Check the adapter on the PC , check if the adapter charges the battery to full capcity , now if this charge wont lat more than 20 minutes , you might need a new one.
Discharge the battery fully and charge few times as the last resort.
Feb 23, 2011 | Compaq Computers & Internet
Booting problem
Unfortunately blinking Caps Lock light on Dell laptops means faulty motherboard. If laptop still under warranty, then bring it back to Dell.
Sep 04, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Nonitor wont Turn on
Thats an hardware issue preventing the computer to boot up.
Please refer to your vendor for faulty hardware, or comment this question for further support
Jun 20, 2009 | ASUS Computers & Internet
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
