Question about Motorola Talkabout T4500 (7 Channels) 2-Way Radio
Hi One of my Motorola T4502 446Mhz Radios is unable to transmit anymore. It still receives though. Any suggestions on a repair would be gratefully received. Regards John Morrison west_highlander2003@yahoo.co.uk
Benimur
  • 6966 Answers
SOURCE: Cannot Receive a signal on either of my radios.
Hi again,
It would seem that you posted twice. Here is the link to your other post with my response.
Cheers.
Posted on Nov 21, 2007
eradiostore
  • 1654 Answers
SOURCE: won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Posted on Aug 21, 2008
eradiostore
  • 1654 Answers
SOURCE: T5420 unable to transmit or receive. Please help!
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Posted on Aug 24, 2008
eradiostore
  • 1654 Answers
Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
This unit does not have a reset button. While troubleshooting you might check the batteries. Be certain they are in correctly and the contacts are free of corrosion. You can use a pencil eraser to clean the contacts.
Walk through all the programming instructions in the manual, double checking both the frequency and interference eliminator codes. A quick setting back to zero on the code would alleviate any problem with that section of the radio.
As far as your "paging" this operates on the same frequency and code as the rest of the radio. If the radios are not working correctly in this relm, the paging will not work either.
Posted on Apr 24, 2009
eradiostore
  • 1654 Answers
SOURCE: Can Receive but not Transmit
1) Double check your interference code eliminator and the Qt filter. Make certain they are all set identical.
2) If you are still having trouble, shut off the Qt filter.
3) Then if you still have trouble shut off the code. (Off is sometimes "zero" or "n" for no.)
4) If the above steps do not help you have either a defective radio, or a bad battery. Switch the batteries out of the working units to the non-working and see if the problem switches to the other units. If so, replace the battery packs. (Note: it takes more battery power to transmit, so the problem would first show up in the transmit area.)
Best regards.
Posted on Nov 10, 2009
Testimonial: "Response from this site is almost immediate! Will try it out & respond asap ... although I must say I dont understand those techie terms:{ TQ anyway!"
T5100 : One radio receive but not transmit back.
check batteries, maybe they are on the way out. otherwise its in the lever connection. old?
May 07, 2012 | Motorola Talkabout T5100 (14 Channels)...
Can you make a baby monitor out of the Motorola 250 model
hello yes you can use these as baby monitors .set one with vox on turn its volume down completly set the channel you require ,secondly the receiver radio set to same channel and that is it though i should state that these radios transmit on pmr band 446 mhz which is widely in use by many people nationwide so they can also listen in to whats been transmitted from your home not very private im afraid !! I would suggest you purchase a wired system hence more privacy and peace of mind hope this helps you
Nov 24, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
I have a radio on my network that I have no trouble receiving transmissions but they am unable to transmit anything.
Barring some serious part or circuit malfunction, the radio may be been programmed to receive only and not to transmit. This is a commonly found setting in the software. A radio shop can quickly find the answer, starting with this possibility.
Feb 28, 2011 | Motorola Radio Communications
My motorola RDU2020 radio receives but does not transmit calls
1) You possibly have a bad or nearly dead battery. Transmit takes more energy than receiving. With this in mind, your radio's transmit will fail, if you have a poorly charged or bad battery, when pressing the PTT. Try a battery from a known good radio to see if it eliminates the problem. If so, replace your battery.
2) The radio is either programmed incorrectly or in need of repair. If you have been experimenting with the programmable features, we suggest you walk back through the steps of programming. Here is a link to the user guide: http://www.mytoolstore.com/motorola/rdx_userguide.pdf Programming instructions begin on page 36.
3) If in need of repair. Radios less than one year old should be under warranty, barring any physical or water damage to the unit. Contact the place of purchase or Motorola for warranty instructions.
If the radio is more than one year old you can get it repaired at any dealer offering Motorola repair. (approx. $85 flat rate)
Best regards.
Jan 12, 2011 | Motorola RDU2020 Two Way Radio
Chinese version t4501, 1 handset tx-ok, rx-not ok
What you are describing indicated the "code" is not set the same on both radios. Check your frequency, interference code eliminator and Qt filter (if any). All the settings must be identical between the two radios. If you are still having issues, set your code and Qt filter (if any) to zero (off) and then try it. Lastly, check your batteries. Bad or poorly charged batteries can cause transmit issues, as it takes more power to transmit than to receive.
Here's a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Best regards.
Dec 18, 2009 | Motorola Talkabout T4500 (7 Channels)...
Apr 24, 2009 | Motorola TalkAbout T5000 2-Way Radio
Does not receive FM signals anymore, just noise.
The T6310 is a disposable radio. Assuming the programming is correct, and matching on each of your radios, and you are using good batteries, there is nothing which can be done to correct the problem. We would however, suggest you double check your programming, and also the age of your batteries.
Sidenote: Rechargeable batteries only last 18-24 months before they begin to fail. Signs of failure can include, but are not limited to, poor transmit, intermittent transmit, white noise, squelching sounds. It takes more energy to transmit than to receive, so your transmit would be the first to go.
Nov 20, 2008 | Motorola Walkie Talkies 2-Way Radio
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
Aug 23, 2008 | Motorola Talkabout T5420 (14 Channels)...
Motorola Talkabout T4500 (7 Channels) 2-Way Radio Logo
570 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
