Question about Toshiba Televison & Video
I have a Toshiba 42wlt58 and it only powers on intermittently. There is no standby light until it does power on. It stays off more often than on. Once its on there are no problems. I have taken the back off and cannot see any bulging/blown caps. I have do not know how to test the capacitors in circuit or out. There is a clicking noise everytime I plug it in. Thanks
  • Toshiba Master
  • 8,457 Answers
Sorry,could be anythings,parts wise in the power supply board.Check the A/C power cord for damages,by shakings or flippings it around while the tv it on.Tries resolders all the transformers,capacitors and the power a/c socket on the board.These are the major points,power comming in and sustance the tv power.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbush power supply board for the replacement.
Posted on Sep 29, 2010
  • andrew richards May 20, 2011
    hello, this is a common fault with the toshiba 42WLT58B , 37WLT58B , 32WLT58B lcd tv range,
    the problem is the power supply, i offer a repair service for this power supply board, prices start at £45.00 + postage so no need to buy a new board as any used 2nd hand board will go the same way over time, all my work is guaranteed and i am a fully qualified tv engineer with over 15 years manufactures training, for more details have a look on my website or email me.
    thanks
    www.andyselectronicstuff.co.uk
My Toshiba 24 inch TV stays on standby red light on won't switch on with remote or power button on tv
You have a shorted circuit board, which one will require testing by a qualified tech.
Jul 06, 2017 | Toshiba Televison & Video
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
TV Not Turning on all the time
Well, needless say I believe strongly that you have an intermittant power supply issue. There are what is called capacitors that act some what like a battery where when the TV powers up it should hold a certain Voltage charge. 'like 5 Volts or 12 Volts'. What is happening is that for these types of TV's they are making the Components 'Capacitor's' much smaller than they have in the older products/TV's and such. These newer smaller caps' don't perform like their older parents and just like a battery. If it doesn't hold up to the Voltage '5 or 12 volts' it won't allow the TV to come on. This is probably why it continues to go back to the standby mode. Will need to go in and get serviced. Don't know Digi home that well. Sony, Toshiba, Samsung all have parts available. Good to stay with recognized brand names.
Blessings,
A/V Guy
Nov 19, 2009 | Cars & Trucks
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
No power
It seems like my toshiba goes into, stanby... i plug it up, and the standby light just flashes.. for a while, and then it stops until i unplug it and plug it back up... it will not come on...
Its like its in standby mold..
Does it need a new lamp..
I looked at the lamp, and it look like it was ok, but i did notice something they may look like bubbles, or something inside, im not sure though...
Feb 22, 2008 | Toshiba TDP-S8 Multimedia Projector
Televison & Video Logo
481 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
