Question about Canon imageRUNNER 5000 Copier
I have a canon imagerunner 5000, error code E602-0001, what does that mean?
    Problem Solver:
  • 7 Answers
Try to change HDD drive
Posted on Oct 04, 2010
Imagerunner 5000 error code e000202 , what mean ? thank
This error code is referencing your scanning lamp just beneath the document feeder. Specifically, it is stating that the home position sensor that detects when the scanner assembly is to the further most left side is malfunctioning. However, as a copier technician, I would advise against pursuing any sort of remedy yourself, as there are numerous high voltage components on the scanner assembly that present a possible danger. Not to mention replacement parts are extremely expensive if you accidentally blow anything out.
My advise, contact someone who is trained in servicing these machines.
Oct 30, 2010 | Canon imageRUNNER 5000 Copier
I have an error 00315-00d...can u help me to fix it...in canon image runner 5000...thanks a lot
hi;
you mean E00315-000d-00
this error code appears when there is a codec error the solution is :
1) replace the SDRAM
or
2) replace the HDD
or
3) replace the main controoler board
Oct 04, 2010 | Canon imageRUNNER 5000 Copier
Canon ir 5000 is giving error 000002 what does it mean
A E00002 code means that you have a problem with the fuser unit.
Aug 29, 2010 | Canon imageRUNNER 5000 Copier
IRC5185i Stopped working. Shows Error code
i looked to see if there was a user fix for this problem but there isn't. It sounds like the driver pcb board could be blown and or the fixing assembly needs replace.
Jun 05, 2010 | Canon imageRUNNER 5000 Copier
Error Message E000001-0000
its a fuser error high temp or lower temp
try to rest this error in *28* FUNCTION,CLEAR,ERROR then on off the machine
if the error the same try to replace tem sensor
Oct 28, 2009 | Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
E000001-0000 error code
it s a thermistor problem
to clear the error do the following.
press additionel functionel* button & press 2&8 at a time &press additionel functionel button* select COPIER>FUN CTION>CLEAR>ERROR>OK.
Aug 06, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
236 people viewed this question
old marine
old marine
