Question about RCA HD52W58 52" TV
Auto convergence issues
The auto convergence option is gone from the menu and all the colors are messed up.
  • Anonymous May 26, 2008
    The auto convergence menu is gone from the TV and the color is all messed up.
  • STEVEO32 Jul 02, 2008
    WHAT DOES SOLDER MEAN
    I HAVE THE SAME PROBLEM
    Genius:
  • 1,030 Answers
This is an indication of fl231 fusable link has blown.. a brown recatangular special fuse that blows due to poor solder connections on flyback. IF you can get the fuse and can solder this is not a difficult repair... EXtreme caution should be taken with televisions. this set can hold 380 volts even when unpluged.. rember resolder flyback
Posted on Jun 24, 2008
50 inch rear projection hd ready model r52wm24 colors have separated and picture is bowed toward the middle top & bottom
sounds like the auto convergence option has disappeared from the set up menu. Press menu and scroll to setup and then enter setup menu and see if the auto convergence is still listed there or has it disappeared?
Jul 30, 2011 | RCA Televison & Video
My auto convergence has disappeared, and my colors are messed up
The ITC222 and ITC222A convergence option missing repair kit fixes tha issue. The kit is available at www.tvrepairworld.com and has complete instructions on CD
Oct 07, 2009 | RCA HD52W59 HDTV Projection Television
I can not find the auto comvergence in my menu
If you do not have convengence when you go to menu then set up convergence should be there.OPEN FUSE FL231 it is on the deflection board Right next the FBT flyback transfomer there are 3 rectangular brown looking caps they are FUSEs the one in the Middle will be open causing convergence failure .They will be on right side of FBT.
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
The color green has come out of the other colors
Needs to be converged if this is a projection tv. Check menu for a cutomer convergence option. Should be a manual or auto convergence. If you cannot move anything in manual convergence then convergence amplifiers are bad and need to be replaced. Professional can replace no problem.
Apr 09, 2009 | Televison & Video
Auto Convergence Problem, no menu option, 3d looking picture
yes the board components are out.not to replace whole board only two convergence ic on the board needs replacement. they are not at all costly this link which is mentioned belkow has all the instructions to replace the ic on the board just click it and follow the instructions  http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Mar 07, 2009 | RCA R52WH73 Projection Television
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Auto convergence
this point to the special fuse fl231 a small rectangular fusable link. .4 amps if you can get this fuse and you can solder repairs is not to difficult.. you have to resolder connections that cause this fuse to blow
Jun 20, 2008 | RCA HD52W58 52" TV
Auto convergence
this is an indication of a special fusable link fl231 has blown it is a small brown rectangular fuse that blows due to poor lead free solder connections on what is known as a flyback.. if you can solder and can get the part i find this repair to be a simple one... Caution. televs\isions can hold leathal voltages even when unpluged... EXTREME caution should be taken
May 26, 2008 | RCA HD52W58 52" TV
RCA HD52W59YX35
just found the problem fuse that causes this to happen. The set I have also was not converging, and the auto convergences option was also gone. The small fuse labeled fl231 which is right next to the big plastic piece with the large red wire coming from it in the left corner of the circuit board closest to the back. It is the middle of the 3 small fuses that are smaller than a Chiclets gum. I was able to pull up the circuit board and jump the fuse with some alligator clips and the set looked great again. Every one says watch out for the unit with that red wire SO WATCH OUT!
damortch check out mouser.com I think I found them on there gonna call them tomorrow to see if I can get mine there.
Oct 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W58 52" TV Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
