Question about Pramac GBW30P Encl Diesel Genset w/Perkins Eng
I have genset FG.wilson P200 ,engine perkins common rail,i have problem because the engine low power loss...i
2 Suggested Answers
  • 251 Answers
SOURCE: low power
Hi ,
firstly i would do a full service on it , all filter and fluids , oil/coolant water,fuel filter(s) and air filters
pay attention to any water seperators , check all fuel line connectors and unions are tight and in good order ( drawing a small amount of air into the fuel system if often the cause of ''a lack of power '')
check your diesel as it absorbs moisture and can severley effect the running of an engine .
if this has no effect
get a rag /goggles and the right size open ended spanner and slacken each fuel injector nut whilst the engine is running , listen for the engine noise going down , if it dosent this means the injector is deffective ( might need replacing or cleaning ) do this to each injector in turn , be very careful as you do this , the diesel is at 200bar pressure and can injected you ( hence the rag )
a final one is the fuel lift pump may be deffective , they often partially work and starve the engine at maximum revs , depending on your engine this will be an electric one or driven directly from the engine block , just follow the fuel lines from your diesel tank ,.
hope this helps
Posted on Jan 17, 2010
I require a service manual for a FG Wilson generator modek P250HE
Can you tell me what control is on that unit. A 2000 or 4001?
Also how old is it? I maybe able to help if I have that
Nov 26, 2013 | Electrical Supplies
How do i align the timing gear on my perkins dk 51280 engine
Timing gears? have you pulled it that far apart? On timing gears there are usually stamped onto the gears a small dot. lign them up. Not sure why tore down so far? If you take off the diesel pump align the timing marks in the small window plate first else you will be in a mess.
Aug 25, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Genset does not start , alarm can't reset
what safety caused the alarm. if you cant restart it, it may be cause the problem that originally shut the engine down has not been fixed, it could be water level, low oil, high water temp, low fuel,over voltage, all of the above are probably run through the safeties. over volt, and water temp would probably clear its self after it sat a while. try turning off power to panel. for a couple minutes and see if it will reset, if not check water level. and oil levels
Aug 12, 2011 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
May 24, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
What is the size Battery (cranking amp) needed for a 3990cc 4 cylinder Perkins 50HP AA Series Naturally Asperated Diesel Engine With a 40KW Generator attached. Thanks, Verner From Florida.
If the unit has a battery box, measure it and get the largest size that will fit and of course the correct voltage. Diesels take a lot to crank.
You can search battery sizes on the internet for physical size. NAPA has a pretty good selection.
Apr 02, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Its 230kvaperkins generator it starts normally,but after thirty minutes it shuts dawn automatically indicating low frequency
Low frequency means the RPM of the motor has fallen off.
Check your fuel is NOT contaminated or fuel filters plugged.
Further tests should focus on the govenor system. Possibly it fails when engine gets hot. the frequency is directly proportional to the engine speed.
Apr 01, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Low power
Hi ,
hope this helps
Jan 17, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Genset can not pick up once main electricity supply is off.
The controller circuit card needs to be replace. This is
the one that senses if and when power is shut off. This
will automatically start the engines.
Nov 03, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Pramac GBW30P Encl Diesel Genset w/Perkins Eng Logo
227 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Dinesh Nagal
Level 1 Expert
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
