My laptop screen isnt working but the cpu itself works. I hooked up an external monitor & it works fine! I tried the FN F5 toggle & still no results
  • 17,130 Answers
It can be that the connection strip that runs through the hinges is broken and cut the supply to the diplay, so check this out.
It can also be a failure of the display drive, the motherboard or a power issue.
But for all the above you will need to open the laptop to check.
Posted on Sep 29, 2010
Monitor is dark. how to fix?
Walt, hold the Fn key down again, and tap once more on the Acer, F5, Display Toggle-Over key.
There are at least 3 display options available;
1) Internal display of laptop ONLY
2) Internal display of laptop AND external display
3) External display ONLY.
Were you just using the external display for more 'display real estate room', or was/is there a problem with the internal display of the laptop?
Was no problem? Is now? Even when using the guidance stated above for the Fn and F5 key?
Then if your laptop uses a CCFL for a Backlight, it also uses a screen Inverter. Screen Inverter is bad.
If it doesn't use CCFL/s for a backlight, and uses LED backlighting, replace the LCD screen.
The LED backlighting is incorporated in the LCD screen assembly, and you ain't replacing it.
Replace the entire LCD screen.
Post the laptop manufacturer name, and model number in a Comment. Model number is on Bottom of laptop.
Try to hurry as I'm going to a meeting with the head of General Motors, (Obama), and later with Bill Gates.
OH I'M JUST KIDDING!
Regards,
joecoolvette
Nov 14, 2012 | Computers & Internet
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
Cannot get the Fn-F5 to work on Acer AspireOne
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Nov 10, 2011 | Acer Aspire One PC Notebook
Im trying to switch to an external monitor on my hp G60-235DX laptop. The laptop screen has been damaged and does not work. Is there an easy solution?
Try holding the 'fn' key and hitting f5 after the external monitor is connected.
This should toggle through the internal / external / both monitor selections.
Sep 12, 2011 | HP G60-235DX Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
Apr 04, 2011 | Computers & Internet
I am using an acer aspire one netbook on xp. i can not make the external monitor that i attach to the serial port to work. is just shows, "no signal" When i press fn f5, it still won't work. please help.
Hi, Could you please post the Model Number of the computer.Are you trying to connect using a VGA cable or a HDMI ?Fn+F5 key combinations are used to toggle the display between the laptop and the External Monitor.Try these steps
1.Remove all cables,Turn OFF computer and Monitor
2.Start the computer and wait till it boots to windows nrmally.
3.Start the Monitor,then plug the cables between laptop and Monitor.
4.Check with Fn+F5 to toggle display
Jun 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
I cant transfer my laptop screen to my pc monitor.. how i can transfer it???
Press Fn key + F5 once or twice. Usually Fn+F5 will toggle you between 3 options: internal LCD - Both internal & external - Enternal only. Wait a moment after changing the mode, as the monitor has to detect the signal and react to it.
Once you are on external only, you can change the screen resolution to better suit the external monitor's capabilities.
With the laptop and monitor active at the same time, both will operate at the same resolution.
Nov 20, 2009 | Acer Aspire 4530-5889 Notebook PC
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Laptop doesn't see the monitor i attach to it
1st off there is a Fn key, I think Fn + F5? to turn the monitor on. It is a toggle button that toggles between only the monitor or monitor and Laptop screen both or just the laptop screen.
I hope that can help, if not, please tell me what you have tried. As in, does the monitor work on another PC/Laptop?
G'luck
Oct 24, 2008 | IBM ThinkVision L170 17" LCD Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
