Question about Dell E193FP 19" LCD Monitor
THE MONITOR WILL NOT STAY ON. IT KEEPS SHUTTING OFF. WE CAN TURN IT BACK ON AND IN FEW SECONDS IT SHUTS BACK OFF. WE TRIED A DIFFERENT MONITOR AND THAT ONE DID NOT SHUT OFF. SO, THE PROBLEM HAS TO BE IN THE MONITOR.
  • Dell Master
  • 17,130 Answers
Whenit power up and stays if the display picture is good, the fault can be a dry soldering, poor joint or a thermal runaway of one of the power circuits.
In all the above you can open the monitor , tap and see or look with a magnifier for visible dry joints.
You can also check if any semiconductor or IC is heating up beyond to shut off.
Posted on Sep 29, 2010
2 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: Monitor shuts off after initial start-up
My 17 inch Norcent LCD was doing the same thing. Then after a couple of weeks the AC adapter failed. I got a new ac adapter now LCD is working.
Posted on Dec 29, 2008
My monitor screen stays on at start up for a few seconds, then turn completley white. Ive tried restarting, shutting down, changing monitors. Whats wrong?
If it happens with multiple monitors, maybe it's not the monitor that's the problem: your graphics card might be dead, and that's why it turns white.
Oct 16, 2013 | Epson Viewsonic ViewPanel VE150M Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Computer keeps turning on and off, plus monitor won't display
Sounds like a loose wire inside the system touching something inside and shorting it out. My brother had this same problem. I brought it to my house to work on it and it was fine, no problems. Open the panel and look for any wires that are touching metal or something else and tie it up out of the way. I won't swear that is your issue, but sure sounds like it.
Jul 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Jan 18, 2009 | ViewSonic OptiQuest Monitor
Nov 21, 2007 | Norcent Technologies LM730 17" Flat Panel...
Monitor (viewsonic e70fb) keeps shutting itself off
the screen has begun vibrating and is very hard to read.
it sounds me that there is some sparking in power supply or high voltage section (FLYBACK) due to loose contact,
your problem of  shut off, I would turn it back on and it would stay on
.might be also due to that only.
please call tech if you are not a tech person.
it is not a major one & simple to fix.
good luck.
Oct 11, 2007 | ViewSonic E70fb (Black) 17 in.CRT...
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dell E193FP 19" LCD Monitor Logo
557 people viewed this question
Clive
Clive
Alun Cox
