Owners maual for rheem # 21vp40e-1a gas hot water heater
  • 234 Answers
SOURCE: I have a probally ancient hotwater heater rheem
You will find two covers on the front.Behind each cover the you will find a thermostat ,there will be adail on it. It might be numbers like 120,150 or it might be letters,like A,B,C and so on.You take screw driver and turn to the right until you get the tempture you want.
Posted on Mar 23, 2009
  • 14 Answers
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Posted on Apr 05, 2009
daddyo742001
  • 70 Answers
SOURCE: Ruud Gas Hot Water Heater Shuts Off
If this is a hot water heating system for home heating It may be thermocouple of flame sensor. If it has a sensor rod in the flame check and make sure flame is hitting it. Also a little sand cloth to polish it may do the trick. I have to due this to my gas furnace sensor every couple of years. If this unit has a pilot light and it is weak and yellow verses strong and blue it may need cleaned. Some times you can tap on it while it is burning and it will dislodge plug. If it A domestic hot water heater for washing and such the above still holds true. If polit is strong and hitting thermocouple then replace thermocouple.
Posted on Jul 04, 2009
  • 115 Answers
SOURCE: Rheem Gas Hot water Heater; Model 21130DV:
yes, sounds like the temp control is bad, you should be able to google model# and thermostat to find replacement. should be fairly easy to swap out
Posted on Aug 19, 2009
SOURCE: Rheem 40 gallon gas hot water heater, pilot light
To make a short story long (I need to include all details, sry)…
I got up one morning and realized that we did not have hot water. I re-lit the pilot light and as soon as the burner went out from heating the water up, the pilot light would go out. After reading several posts regarding this issue, it seemed apparent that the thermo-coupler was the problem. Since I am a little bit handy around the house and very tight when it comes to opening my wallet, I bought the device from Lowe’s ($8.98) that was recommended by my online advisors and after a few googles, figured out how to change it. No help. The pilot light still goes out.
I gave up and went to Home Depot to purchase and schedule the installation of a new hot water heater.
STICKER SHOCK
A new Direct Vent type water heater costs around $800 with an additional $450 for “special” installation. Add a few fees to that and the grand total came to about $1450.
I felt like I had no choice since my wife and 2 daughters refused to live their life without hot water and I had no clue about how to fix the dam thing.
The plumber assigned to the installation stopped by to evaluate the site conditions and quickly noted to me that the 8 year old water heater tank was in good condition and that the gas controller was probably faulty, which could be purchased online from the manufacturer. I quickly cancelled the Home Depot order and purchased the controller for about $120 after shipping and tax. Immediately after the installation it seemed that the problem had been solved. A few days later the pilot light went out.
I called the plumber and explained the situation and he recommended that I purchase another controller because the one that was shipped to me was probably bad. I searched around town and found a plumbing supply company that had the correct model in stock. Two days later the pilot light was out. I cleaned up the controller and returned it to the store and asked the plumber to please schedule a visit to repair this dam thing.
When the plumber arrived, he hooked up a gauge in several locations and confirmed that the correct amount of gas (cfm) was being delivered to the controller, pilot light and burner. He then proceeded to remove the fire box to make sure that the igniter, thermo-coupler and pilot tip were set properly. He inspected the pilot light tip and said that he found the problem. Using about a 1/64” tip drill (can be purchased at a welding supply store), he cleaned the tiny hole that releases gas to the pilot light. I felt a sigh of relief because I was certain that the problem had been solved. $65 dollars (plumber’s fee for an hour of work) and 4 days later the pilot light went out.
I called the plumber and he said that the controller that I purchased online must be bad. Too embarrassed to return to the first plumbing supply store, I found another one in a different town that had the correct model in stock. Three days after changing the controller the pilot light went out. I returned the controller and a six pack later I decided to do some extensive googling.
The key term here is “DIRECT VENT”. This seems to be a very common problem with direct vent water heaters and I was about to find out the reason for this phenomenon. I read a post by an individual who wrote that if the vent becomes detached that the inflow of air can become contaminated and extinguish the pilot light. I decided that before I spent any more money on a plumber that I was going to take the vent apart and find out what makes it tick.
My direct vent system has 2 parts to the venting, an inner pipe (3” nominal diameter) that serves as the exhaust and the outer pipe (5” nominal diameter) that serves as the internal flow of air which supplies the pilot light and burner with oxygen. On the outside of the house a vent hood helps to segregate the two by extending the exhaust about 3” beyond the intake. I looked into the hood at the end of the pipes and discovered that the internal pipe which consisted of a 2 piece slip joint had come loose from the elbow that sets on top of the water heater. This slip joint pipe was not attached at any point with screws or clamps and was loosely setting over the elbow on one end and into the hood on the other end, allowing it to detach. Apparently, when atmospheric conditions were right, the burner idled down from heating up the water and extinguished the pilot light because the intake was saturated with CO2 from the connection failure.
I purchased a section of 3” pipe that was long enough to be installed in one piece. I connected it to the elbow using a stainless steel hose clamp. I had to disassemble the pipe 3 times to make adjustments to the length and position before I got it right, but I should not have any more problems with the pilot light.
The problem here is time. It takes a lot of time to get this right. When the plumbing contractors installed this unit during the construction of the house, there was no one around to make sure that they got it right. It is probably common to use a 2 piece slip joint type connection, but I feel like it should be attached with screws or clamps. In my opinion it is not rigid enough and can detach easily, especially if it is not installed properly. A one piece connection that is attached at one end with a hose clamp and then held in place at the other end by the hood is fool proof.
Posted on Sep 27, 2009
I own a salon and have 2 Rheem 60 gal 50,000BTU Gas hot water heaters. I am still running out of hot water during the work day. My question is because the hot water heaters are on the 3rd floor, it is...
I think before I spend the kind of money to get a tankless added I would get the rheems serviced . two should produce more hot water than 30 people could shower with all day
Feb 21, 2015 | Rheem Water Heaters
Rheem pronto tankless water heater just barely warm model # 74pvn-1. This is in a house we are just purchasing. Also it looks like it may be attatched to another tank water heater , Help please
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sometimes people attach tankless to tank-type heater to preheat incoming cold water.
Additional tanks are also used to store solar heat, and some installations have tank-type because tankless is unreliable. Service technician can sort out the function correctly.
http://waterheatertimer.org/Tempering-tank.html
Owner should read tankless manual thoroughly, especially troubleshoot and maintenance sections. Tankless require yearly maintenance.
Since tankless are expensive to repair and replace, you might be able to fire up the tank-type water heater and provide hot water without much cost.
You can also install tank-type gas water heater yourself. Lowes sells 40 gallon for $317.00, and then you offer 10% less.
http://waterheatertimer/How-to-install-gas-water-heater.html
Apr 19, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
No hot water.Error code:C2 11 (Rheem GT 199-PVN-2)
Resourceful do-it-yourselfer will find following links valuable
1) C11 is 'no ignition'
Check following link for Paloma error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
2) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
3) Typical Rheem manuals
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
http://waterheatertimer.org/pdf/RHRheem-Hvy-Dty-IndoorOutdoor.pdf
http://waterheatertimer.org/pdf/Tankless_Condensing_AP15896.pdf
4) Rheem site where you can find and download your manual if it shows
http://www.rheem.com/hrc.aspx
5) Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
6) Contact Rheem
http://www.rheem.com/Contact.aspx
7) Search Fixya for Rheem questions and answers
http://www.fixya.com/tags/rtg_74pvn
8) Post question on pro water heater forum: This is where I go to catch up on always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
9) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
10) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Rheem GT-199PVN Heavy Duty Indoor Natural...
How can I get an owners manual for a Richmond's tankless hot water heater? Allso the instructions to install. Model # RMTGL74PVN Serial # RMLN0109JO1242 Thank you, Mark
Try this link.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1298033256538/pdf/ownersmanuals/rheem/RTG74IndoorOutdoor_owners.pdf
Feb 18, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm: hi i have a rheem tankless water heater, with flas...
Sounds like you may have the wrong type gas going to this? Is this an LP gas or natural gas unit? will say on label. Natural gas units run only on natural gas ditto for LP. Could be issue with manifold pressure settings. Could be obstruction in exchanger or vent. Have a authorized technician check over
May 17, 2010 | Rheem Tankless Hot Water Heater...
I have a Rheem 21VP40E Power Vent NatGas water heater. It was with the house when we bought it. The problem is that lately we are only getting one shower out of the unit. Even during that one shower the...
As long as the tank is not leaking. Go to Rheems website, and look up your model.
As with any large home appliance I would recommend a plumber or HVAC professional licensed by your state to perform the repairs.
I am pretty sure the part you need will be the gas valve contoller.
Please elt me know what you find.
Feb 10, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
352 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
