Question about Kenmore HE2 Plus Front Load Washer
Uses to much water,fiils half way up the glass with water///and really uses alot of water on express wash
  • Kenmore Master
  • 17,130 Answers
Set the washer with a low water level settting to confirm if the clothes are soaked in , if the water level does not go down it is possible that the water level pressure switch is faulty.
Posted on Sep 29, 2010
Water streams from panarello and coffee spouts when making a coffee
Some express coffee makers are "sensitive" to the type of coffee and the way you fiil them. What you describe happened to me when I use s coffee too fine grinded and too compacted
Jul 29, 2015 | Saeco Incanto Classic Coffee Machine
Hotpoint wf865 1600 spin, whilst washing alot of water is coming out of the washing machine
OHOHOH water comming out of the machine.
You have cleaned drain pipe and the opening as well as the glass. You will find that if after this cleaning process and take a short wash with old pillow cses, Hvis der setter sig a lot of debris in the material, there is still alot of cleaning to do.
kolbrun
Feb 25, 2012 | Hotpoint Washing Machines
Washer will not fiil. sound like it is trying to drain, but there is no water in it
CHECK YOUR PRESSURE SWITCH IT PROBABLY THINKS ITS ALREADY FULL. TRY REMOVING THE VACUUM LINES AND MAKING SUTRE THEY ARE NOT PLUGGED UP.
Sep 24, 2011 | GE Washing Machines
White film especially on ziploc containers and utensils. Glasses come out spotted and clear glass dishes are streaked with a white film
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Please post back if more information is required.
Daniel
Aug 07, 2010 | Dishwashers
Ice is forming around the auger under the ice bin. constantly have water dripping from ice cube shoot
the door that the ice comes down to fill glass is not closing; the ice chute door just above the lever to fiil glass with ice it is either jamed with ice or is broken and needs a new repair kit.you can inspect by opening door and look at approx. 3 inch door that ice falls threw to see if closed.warm air causes ice to form.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking on fill , fiil hose is not leaking , appears to be comins out under tub
either your tub seal is getting bad between tub and transmission or your "water fill" tube to the "size of load" water fill control on control panel has a leak in the plastic tube
Aug 25, 2009 | Maytag Washing Machines
Top wash rack doesn't get water
does the unit have a half load selection? if so then it may be stuck in half load due to a faulty solenoid in the base.
Mar 14, 2009 | Dishwashers
Washing cloth diapers
You could, however do not add above the bottom of the door glass. I do this alot on our machine. also use the extra rinse option.
Sep 22, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore HE2 Plus Front Load Washer Logo
56 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
