Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Mashine make noise and vibrating a lot - Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
  • 2,382 Answers
Hi, your washing machine makes noises because all the clothes and other materials are not balanced evenly--one side is heavier than the other--causing the drum to hit the sides of the washer wall.
Posted on Sep 29, 2010
When on spin getting a lot of vibration and noise
inspect the shock absorbers if noise is coming from the back during spin cycle
Dec 06, 2012 | Washing Machines
Washing mashine jumps around during the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 25, 2011 | Kenmore Washing Machines
Washing mashine make a huge noice
Washer Problems
heatman101
Dec 30, 2010 | Washing Machines
Experiencing extreme vibration and noise with my LG WM2101H...sounds like a rocket is taking off everytime i wash something...it's on a pedestal, overflow pan and is located on the second floor...no...
This is actually pretty normal for newer LG front loaders. They've done a lot of work to isolate the vibration and noise from the spin cycle, but the higher RPM's have countered those improvements. Unless the manufacturer/technician can determine that something is actually wrong, you're probably going to need to install an anti-vibration pad under the washer pedistal to absorb most of the noise. It is very likely that the subfloor is actually amplifying the vibration into the "rocket" noise that you are hearing. Try installing Silent Feet anti-vibration pads or similar to prevent this amplification of the noise and vibration.
Mar 04, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Vibration/Humming/Grinding noises when stopping or turning left.
when turning left vehicle distributes weight to right front wheel bearing causing load. since u describe a noise in right front while driving straight i would suspect failed right front wheel bearing. see if your noise changes/goes away while turning right that should tell u 4 sure
Nov 15, 2009 | 2004 Chrysler Town & Country
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Vibration of the wash mashine
How old is the machine? Have transit bolts been removed? Older machine is possible bearing failure or spider breakage( a 1 in 10 wash with a temperature of 95 degrees celcius will extend life of a front loader!- an empty wash or towels or sheets at this temperature). A grinding noise can simply be a worn drive belt, rotating drum by hand and finding grinding and lateral movement equals bearing/spider failure. Also a simple case of Underlaoding the machine will cause unbalanced load and vibration.
May 22, 2009 | Washing Machines
Maytag performa off balance
Check the vibration dampers and the plastic mounts for wear. They should be solid to the machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Washing Machines
Samsung WF337AAL/XAA washer- washing mashine with noise reduction but when it spins we hear a lot of noise and the unit moves. What can we do?
I have had mine for 6 months. I noticed that they must be on a flat smooth surface. If the surface is not level you will have that problem.
Jul 13, 2008 | Washing Machines
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
182 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
