Question about E-Machines eMachines Desktop PC
Rebuilding emachine - windows 98SE
Greetings!
My father in-law is in the middle of refreshing an emachine with Windows 98SE and received an error message C100 and can go anyfurther with the reboot cd's from emachine. Any suggestions on how to proceed past this?
    Sergeant:
    Champion:
  • 326 Answers
A C100 error is a registry error. I suggest that U format the drive and reinstall the 98SE. There are programs (bought) available that may fix this problem, but another perferred choice would be to purchase a XP operating system. Boot up on the XP cd and replace the 98SE with the XP. It's better, faster, prettier and more reliable.
Posted on May 25, 2008
Hello my father in law gave us a Belkin F5D8230-4
You need to install the serial number in your computer off of the router, clcik on diagnose and when it comes up with enter pass phrase input your serial number ans you should be connected. Hope this helps and thanks for using fix-ya.
Jun 21, 2010 | Computers & Internet
My father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
Sep 18, 2009 | John Deere 420,1020,2010,2020,2510,2520...
NTLDS missing when installing windows 7
Before tring to install Windows 7 I suggest you download (or your in law) from Microsoft a utility program that detects your hardware and tells you whether the system will support this RC version of Windows. Download "Windows6.0-KB947821-v4-x86 Update Readiness.msi" and run it on the system prior to installation. If your system is already damaged, install a base WinXP OS on it and try it. Good luck!
Aug 16, 2009 | Microsoft Computers & Internet
My emachine will not connect to the internet i have dsl through at&t. is there any way to receive realtek driver without going online
yes and no.
1.) you will have to get online on someones computer and find the driver and save it to a flash drive or cd
2.)If your nic is still not working goto http://www.codebluehelp.co.cc/downloads.html and download winsockfix put it to diskette, cd, or flash drive and use on your emachines.
Hope this helped.
Mar 17, 2009 | E-Machines eMachines Desktop PC
Monitor works in dos starup, but fails in Vista startup mode.
Sounds like windows resolution or refresh rate is too high for the 15" monitor. Try starting in safe mode and setting the resolution below 1024 X 768 and refresh at 60. Restart.
Mike
Feb 16, 2009 | E-Machines eMachines Monitor E15T4
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
My Camcorder Is Not Detected By The IEEE Card.
1. CHECK CAMCORDER CONNECTIONS AND SETTINGS. 1. The DV Camcorder is turned on and connected by the power adapter (not battery) 2. The Camcorder is in Play Mode. 3. The IEEE 1394 cable is properly connected from you camcorder to the IEEE 1394 card. If you have checked these steps and the camcorder is still not detected, then the camcorder driver is most likely not loaded. 2. CHECK DEVICE MANAGER TO VERIFY THAT CAMCORDER DRIVER IS LOADED. 1. Go to Device Manager by clicking on Programs > Settings > Control Panel > System. (In Windows 2000 you have the additional steps of clicking on Hardware > Device Manager). 2. Under the device heading called Imaging Devices, you should see a device called "Samsung DV Camera or DV Camcorder". If you have an exclamation point "!" on this device, highlight the device by clicking on it and then click the Remove and Refresh buttons for Windows 98SE and ME. For Windows 2000, click on the uninstall icon, then click on the scan for new hardware icon. Even if the camcorder device does not have an exclamation point "!" on it, you can remove it and reload it. With Windows ME and Windows 2000, and Windows XP, the 1394 camcorder driver is built into the operating system by Microsoft and is already loaded on your system. With Windows 98SE the files are located on the 98SE CD in the Win98 folder. If the device is not listed, please check all of items in step #1 above. If it continues to be a problem, there may be a problem with the: 1. Camcorders firewire port 2. 1394 cable 3. The 1394 host controller card Samsung does not support Firewire Components. You must consult the manufacturer of your Firewire product(s).
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
E-Machines eMachines Desktop PC Logo
57 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
