The part you which to get can be order for at the below site if you can not get/fine it at any technician store located around you
www.askmehelpdesk.com www.handymanhowto.com www.askmehelpdesk.com
All the above site offer a competitive price to there customers, so you can go on shopping if you which to take the step of do it your self
Thank you and thanks for visiting fixya.
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status:
In Stock
Price:
$107.79 -
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
